VIBRATION FROM TIRES OR FROM SUB-TOOLS
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 17:08 # 1
gkn406
FRIENDS HELLO ... I WILL BE A MEMBER OF A FORUM FOR THE FIRST TIME AFFOLA ...
WILL BE A QUESTION TO YOU;
& nbsp;
- MY CAR PUG 406 SV MANUAL 2.0 2000 MODEL
- QUESTION IS - I CHANGED THE TIRES I WAS NOT REPLACE. I CANNOT BREAK TO THE MONEY IN WHICH I DON'T Skip ANY MAINTENANCE. I DID NOT HAVE A FIRST AND A LARGE MONTH TROUBLE. BUT AFTER VIBRATIONS STARTED IN MY CAR I noticed the humming sound after & nbsp; MASTERS SAID THE LEFT FRONT AND RIGHT REAR BALLS. THIS WAY I USED UP TO 1000-1500 KM. I changed the balls when the humming was unhealthy without healing. THIS TIME WHEEL IS DIRECTED, BUT THE VIBRATION IS NOT FEELED AS IT IS FEELED. MENTED BY THE HEAD OF AXLE. WHEN THE BALANCE IS OVER, I SAID A LIGHT SHAKE IN THE TIRE MECHANISM WHILE I RETURNED TO THE MASTER. He said that it would not be in quality tires. WHEN CAN I BREAK THIS VIBRATION WHY CAN I BREAK THIS VIBRATION? WHAT IS THE POSSIBILITY OF BEING FROM THE AXLE WHAT IS THE POSSIBILITY OF WELDING FROM THE TIRE? DOES THE VIBRATION DO NOT INCREASE IN THE LOAD THOUSAND OF THE VEHICLE THAT WAS AT THE HEAD OF AXLE? OYSA WHEN I DOWNLOAD GAZA, I START IT TO FEEL AT 75-90 KM SPEEDS AND WHEN I DON'T GO INTO THE BOTTLE & Nbsp; THIS VIBRATION. 150-160 OR 170-180 E & nbsp; I FEEL LESS THAN WHEN I REMOVE AND RELEASE (nBM) & nbsp; I FEEL LESS (SURVEY ON THE CAR)
& nbsp;
& nbsp; / div>
08.05.2020 17:08 # 2
fatihgg
The great majority of wastes do not balance, I think this brings many faults afterwards, teams, balls etc ..
08.05.2020 17:08 # 3
gkn406
BUT THE ORIGINAL DIMENSION IS TACTICAL + VIBRATION WAS NO PROBLEM WHEN I TAKE THE TOOL FIRST.
08.05.2020 17:08 # 4
KenBlockJR
Have you tried and put the rear tires forward?
08.05.2020 17:08 # 5
gkn406
THE BALANCE MASTER HAS ALSO TELLED, LET'S BECAUSE IT HAS BEEN DISCOVERED, WHICH WILL BE THE BENEFIT OF NEW TIRES.
08.05.2020 17:08 # 6
fatihgg
When you have a new vehicle installed, they will give the vehicle a new tire with a rot balance adjustment.
08.05.2020 17:08 # 7
KenBlockJR
[QUOTE = gkn406] THE BALANCE MASTER HAS ALSO LIKE IT LIKE BUT IT WAS ALSO GAVE TIRES. it happened to me in my old car. At 120km there was vibration on the steering wheel. There was nothing on the rim or the tire, but it got better when it did the front-back.
08.05.2020 17:08 # 8
gkn406
I THINK THAT LIKE TIRE QUALITY, BUT I WON'T KNOW THE HEAD OF THE AXLE.
08.05.2020 17:08 # 9
bahcekapili
Most likely from tires. I bought 2 Sumo Firenza tires last year. Let the problems started before 1000 - 2000 km more than 500 km. It never balances once. You are doing your way and the event is over. Just like you mentioned, vibrations.
& nbsp;
Then I went I bought a Good Year production Sava tire. I have not been balancing the car since May 2012. I was going to change almost the entire undercarriage, but if something like this happens to you, let's get the tires you change first. At worst, make it front and back.
08.05.2020 17:08 # 10
pt206
I have been using GT Radial tire for 2.5 years. As you said, everything was good at first. After a while, it started vibrating after 110 km speed. I did not do any back front but I was thinking about having it soon. It vibrates from 110 to 130 km, 130 to 190 I do not think:) I think it is made of tires. After experiencing this situation, I can say that I will not buy a cheaper tire :)
