VIBRATING AT BRAKE PRESSURE!
08.05.2020 18:32 # 1
D.EAGLE
First of all, hello friends, even though I do not have short braking distances in my car, there is a tremor that I feel when my foot is on the brakes when I am about to stop at long braking distances. Dead
08.05.2020 18:32 # 2
Serkan
Tremors generally do from discs, and sometimes the pads can be used until they get used when they are newly installed.
08.05.2020 18:32 # 3
DeRyCK
If the disc and pad have just changed, it may tremble during the habituation process. If the new hasn't changed, the disks are probably warped.
08.05.2020 18:32 # 4
D.EAGLE
There has not been a change for a long time, friends, neither disc nor pad.
08.05.2020 18:32 # 5
Burak
Both of them are over, then take a look at the thesis.
08.05.2020 18:32 # 6
ibanez_022
ABS?
08.05.2020 18:32 # 7
D.EAGLE
yes, but my brakes are so strong I think this should not be an indication that it's over .. Could it be related to ABS ??
08.05.2020 18:32 # 8
Mustafa-almanya
Don't expect the balance of the rims, a BMW I bought 4 new tires before, the tremor started, I immediately went back from the road to the tire tire, he insistently said from the brake, but I said the only thing that changed was the tires. They did it again, the car was like a reed.
08.05.2020 18:32 # 9
D.EAGLE
my rot-balance balance is new teacher, but if I do it again, the master way will appear if it does not improve again Stern Smile
08.05.2020 18:32 # 10
simirnoffredbull
If you are talking about the vibration of the pedal that will press hard on the brake, the abs will be activated. change the front pads when you change them, or the disks will take the shape of the pad again.
Note: Shaking the brake is not related to balance. If the balance is bad, it will make the vibration at its speed, not the pressure
simirnoffredbull 2014-05-10 19:54:37
08.05.2020 18:32 # 11
D.EAGLE
ABS system comes into play in hard and sudden braking, I know it, hod, but it is not. ..I think you have to look at the pad and disc as you said thanks.
08.05.2020 18:32 # 12
simirnoffredbull
about 250 TL 2 discs 2 pads :)
08.05.2020 18:32 # 13
D.EAGLE
[QUOTE = simirnoffredbull] about 250 tl 2 discs 2 pads :) [/ QUOTE]
of course there is workmanship Cry Anyway, let's get health in solving the problem :)
