VIBRATING 307 DEPARTURE
08.05.2020 19:06 # 1
UP.969
Friends 2005 model (NO LPG 125.000KM) 307 1.6 XT PREMIUM when I take off my feet from the clutch when I take off, it trembles and jerky off at the full grip point. Clutch is grasping in the middle, it is not as if it is over, but it is also good to grip but I would appreciate it if it can help with the reason why this tremor may help.
08.05.2020 19:06 # 2
monalos
I do it too, by the way, I think it originates from me, it doesn't shake when I give the gas a bit more,
But you had something related to the subject. I read something like volant or something in the forum. But I don't give false information.
Ben 10 vibrates when lifting at throttle, not vibrating at 12-14
08.05.2020 19:06 # 3
UP.969
It is almost non-existent at high speeds, but it is felt to disturb around 1000 cycles. I think to go to the authorized service on Sunday and ask.
08.05.2020 19:06 # 4
monalos
If you ask me, it would be good, he's doing it with me, but I usually set it to 12-13 so I take off my foot like that,
the master has tofaş, idling, no vibration: D
08.05.2020 19:06 # 5
xmen
Have you changed the pads recently? If you haven't changed it and you don't know when it has changed, your print pad is most likely to last its lifetime.
08.05.2020 19:06 # 6
monalos
My printing pad is new, changed to 1.5 years, how many years does it change?
08.05.2020 19:06 # 7
swing67
I had the same problem, too. I bought it at 25 TL. The workmanship is very easy. When you lift the car, it becomes clear that it looks deformed. I have a printed pad flywheel etc. I thought, but I solved the problem very easily.
08.05.2020 19:06 # 8
gungor
1. si printing ends the pad
2.If you change the lining of the lining, make it look in the mirror, flicker from the mirror.
even if the pad is new
08.05.2020 19:06 # 9
xmen
the replacement time of the printing pad is not constant. that is, depending on the user, it may vary depending on the load of the vehicle. already more or less self-evident.
08.05.2020 19:06 # 10
monalos
[QUOTE = swing67] I had the same problem, too. I bought it at 25 TL. The workmanship is very easy. When you lift the car, it becomes clear that it looks deformed. I have a printed pad flywheel etc. I thought, but I solved the problem very easily.ihs is the same problem as yours [/ QUOTE]
Just as I put it in 2nd gear, I put it in 2 and put it on.
08.05.2020 19:06 # 11
UP.969
I did not change it, I think it may be from the press pad, but on the one hand, it suggests that there is no problem in grip.
08.05.2020 19:06 # 12
monalos
there is no problem in grip, there is no kidnapping on departure.
08.05.2020 19:06 # 13
UP.969
I changed the lower wedge but it has not improved I suspect the upper wedge and let's see what the service will say!
08.05.2020 19:06 # 14
xmen
If your vehicle is shaking at idle, suspect the chocks. but I do not think it will be wedges if there is tremor in the departure. I had shaking at idle. the wedge has changed. sometimes I don't even feel the vehicle is working LOL
08.05.2020 19:06 # 15
monalos
I do not understand that it is working as you said, no shaking in idle.
08.05.2020 19:06 # 16
Faruk
like the flywheel you have described.
There was trembling in me too, it was not getting off especially on the ramps, but it was like that when it got hot.
is already warming up right now: D
I changed the flywheel twice in 5 years due to my father's half clutch.
The expensive meret in the diesel cost around 1700 both separately.
08.05.2020 19:06 # 17
muro_60
makes from clutch lining. in a possible way, the oil will run out of the grinding lap, this will cause the lining of the lining, the room will make the shaking.
08.05.2020 19:06 # 18
UP.969
I guess it would be better if I do not go to the service these days.
08.05.2020 19:06 # 19
muro_60
[QUOTE = UP.969] I think it would be better if I don't go to the service these days, it seems that the tremor will explode expensive [/ QUOTE] invisible pad looks like 250 pads 150 jobs
08.05.2020 19:06 # 20
UP.969
I hope we will save that much, thank you very much for your answers.
Page : / 2
