very urgent ABOUT 308 THP
08.05.2020 15:07 # 1
kivancxxx
Friends first greetings to all of you. My 2008 model 308 thp 150 hp car burns 400 lira.
I need your suggestions if there are any positive or negative ... thank you in advance ....
08.05.2020 15:07 # 2
ramtas
In 400 lira gasoline, the ii figure makes 10 liter in the tube at 100km. I think it doesn't go under 300 cents in the tube.
08.05.2020 15:07 # 3
kivancxxx
I don't touch the gas much now, but it doesn't burn down from 370 again. and 185 pounds are filling up. Sometimes it does not even see 500 km ... if it is like your dedication, it burns 10 liters at 100km and at least 250-300 km more than this amount (185tl). But there is something in the knight, I ask for the peugeot engine before. 230 kurus yakuodu .... lpg trouble in this engine and brand .. ???
08.05.2020 15:07 # 4
sercinho
My brother, the problem does not arise, you are consuming a few liters of fuel at the moment, but I do not know if it is stuck on thp engines.
08.05.2020 15:07 # 5
As far as I know, I can't attach lpg to thp machines. Because the engine works with a direct injection spraying system. I have read from the site of the prunes that it can be attached to some of the pipes and fsi having the same system. but how many of them work stably, I can not stop working. Because it is sprayed with LPG without using separate injectors ... I think you should do a good research. a friend of mine had asked me with the request to wear a lpg machine thp machine.
Also how smooth it will work if LPG can be installed. If it works efficiently, if you consume 10 liters of gas, you should consume 11-11.5 lt lpg.
On your 1.6-liter engine without a turbocharger of your vehicle, it should be treated as lpg. some say it is happening some say it is not happening. I have it on your face :)) but I did not come across the lpg one, personally.
08.05.2020 15:07 # 6
kivancxxx
The average kmla ranges between 360 and 430 km.
08.05.2020 15:07 # 7
kivancxxx
today i went to the zavolli dealership .. zavolli special superkit turbo and high horsepower cars for the price ... more expensive for the price of 400 people. You don't live because he said these superciters were produced for precision motor vehicles like yours ... but how to guven ....
08.05.2020 15:07 # 8
Ask the guys for a reference. Talk with other car owners to wear that model. What good idea they give you about it.
08.05.2020 15:07 # 9
Many brands already have scarcity for stronger and turbo cars. this is not a new event. My waste dealer has applied super kit to my friend Mercedes SL55 AMG machine.
The issue here is the engine's fuel spray system. I wonder if the friend who said these words knew that the direct injection system was used in your engine? it may or may not know.
It is not easy to apply direct injection engines. If it can, it is necessary to scream ...
