Very rapid fat consumption
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
25.02.2026 03:23 # 1
terminus
Hello, I own a 2016 Peugeot 208 1.2 PureTech ETG5 85hp. It currently has 123,000 km on the odometer. Last month, I checked the oil level and found it was very low, so on January 19th I took it to my mechanic, who added 4 liters of oil. At that time, the mileage was around 121,000 km. Last night, February 24th, while driving slowly over a speed bump, I received a "oil pressure pump malfunction - have the vehicle repaired" warning, and shortly afterward, the yellow engine warning light came on. When I checked the oil level, almost no oil was coming to the dipstick. I added 2 liters of Total Quartz Ineo First 0W-30 oil, which I kept as a spare in the trunk, and drove home in 25 minutes without any problems, although the yellow engine warning light was still on. I didn't use my car at all today. When I went to check it this evening, I saw the oil level on the dipstick was almost at maximum, and the yellow engine warning light on the dashboard was off. How did I use up 4 liters of oil when I've driven around 2,000 kilometers between January 19th and February 24th? What should I do about this? My research suggests blue or other signs of oil leakage from the exhaust. The issue of smoke emission has been mentioned, but I haven't experienced such a problem, and I've checked that there hasn't been any oil leakage from under the car. I've researched and seen that 1.2 PureTech engines can consume oil quickly and that the timing belt should be replaced at 80,000 km, etc., but I don't know what to do about this problem right now. What could the problem be? Should I take it directly to an authorized service center? Thank you in advance for your valuable opinions. integrity="sha512-ZpsOmlRQV6y907TI0dKBHq9Md29nnaEIPlkf84rnaERnq6zvWvPUqr2ft8M1aS28on72PdrCzSjY4U6VaAw1EQ==" -cf-beacon=""version":"2024.11.0","token":"11ac6a036a5c4b83a3c20a30a3bc3ba2","r":1,"_timing":"name":"cfCacheStatu s":true,"cfEdge":true,"cfExtPri":true,"cfL4":true,"cfOrigin":true,"cfSpeedBrain":true,"location_startswith":null" crossorigin="anonymous"> terminus2026-02-25 03:33:09
