Very light whistling sound from the engine?
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 301
08.05.2020 21:01 # 1
vpro
Guys, I'm disturbing again,
After 2 thousand cycles from the engine, there is a very soft whistling sound. Since I was a little clicky, I looked at the internet a little. They say Turbofan comes very light. Do you think this sound makes sense? Doesn't it sound like the pressure when the car is stopped?
08.05.2020 21:01 # 2
HasGur
[QUOTE = vpro] Guys, I'm disturbing again,
If the sound comes only when the vehicle is in motion, there may be a problem with the wheel bearings. It is normal that the engine is cold or when the engine oil is cold, when the speed increases, it is normal to hear very little noise from the turbo, but it should not be heard after a short time when the oil starts to warm up.
08.05.2020 21:01 # 3
vpro
It comes when the engine is warm, it feels very light, I hear more on the slopes. There is no sound when we press the gas while the car is stationary.
08.05.2020 21:01 # 4
If it comes on the move, at what speed my teacher is, the insulation of the 301s is weak. Our brother has already said @HasGur.
08.05.2020 21:01 # 5
vpro
My teacher usually comes between 80-110. No sound when going slow. It may be coming from disks or something. They squeak a little when they press the brake.
08.05.2020 21:01 # 6
that sound is usually from glass filters etc. A general complaint that sounds too much bro. it may happen in brakes, sometimes a small bend in the disc causes friction of the pads. Let's have a nice clean with the lining spray. will i sue
08.05.2020 21:01 # 7
vpro
Okay, let me take my sonerkyl lining pad spray and apply it. I hope it goes
08.05.2020 21:01 # 8
Selcuk55
A small amount of whistling sound coming from the turbo is considered normal, cold hot does not matter, a small amount of income does not exaggerate, nothing will continue
