vehicle towing
08.05.2020 18:28 # 1
sezar206
Dear friends, mine is 1.6 90 hp, how is your vehicle towing on the long road? My car is full of luggage when there are 3 people in the car full of luggage. But of course I have a fairly steep hill. The vehicle falls into gear. At the last speed, I was driving down the road with a slight downhill at 5th Vts. Are they normal?
08.05.2020 18:28 # 2
ahmet_bjk
I am satisfied with the traction of 1.6 HDI 90 in 308, it is enough even if you do not lean back.
As for the final speed, I saw 200 on the light downhill freeway and it didn't go any further. But 206's gear range may be different. Last speeds of friends who use 206 are more important to you
08.05.2020 18:28 # 3
newlook45
absolutely normal mine is 1.4 karabük ankara, we constantly climb up and down to the toll booths, i have to constantly fall down to 4, sometimes even 3 to me if you want to reduce the recommended fuel consumption, go up the hill at a speed of + 40- + 30 km, at least you don't shift gears and waste more fuel
08.05.2020 18:28 # 4
C@GL@R
Although the 1,4 75 hp 206 vehicle is full, there is no excessive drowning.
08.05.2020 18:28 # 5
sezar206
1.4 is yours, but. For fuel, I enter a little faster before going uphill. However, if you do not use bottom gas in 5th gear, it will be more economical if you take off with 4th half gas in 4th gear. As a result, the more urgent you press the gas, the urgent the butterfly.
08.05.2020 18:28 # 6
sezar206
Gncl
08.05.2020 18:28 # 7
samet206
It is normal, there is no problem, if the vehicle does not eat gas, it is another tab, for example, you can tick it at 3 o'clock, you threw it up to 4, but if it forces you to fall back to 3, you can doubt the vehicle, if it always does this way. filters, you can look at the spark plugs and you can clean the gasoline tank. If you use the vehicle with gasoline, these will have a great effect on the traction.
08.05.2020 18:28 # 8
sezar206
I can start the pressure too high. Is there a lot of impact on the towing of the vehicle?
08.05.2020 18:28 # 9
samet206
[QUOTE = fatihpekgoz] I can start printing, it is very upset. Is there a lot of impact on the towing of the vehicle [/ QUOTE]
Of course, I feel like I changed my thrust pad last year, for example, when I reached a speed of 3500 rpm 50 km in 2nd gear, now I see 40 rpm in 3500 rpm, but the traction you mentioned is a bit different, but part of the traction is a bit of heavy and other parts of the vehicle. If there is no defect, it always causes pressure pad.
