Vehicle stumbling when getting up
08.05.2020 18:28 # 1
nofear308
Mrb friends I am using 2008 308 vti kmsi 75 thousand when my car gets up at 1st gear stumbles when i press the clutch and it feels like it knocks very little when i get to the bottom ??
08.05.2020 18:28 # 2
IBRAHIM ASIL
teacher, you had to force the vehicle during take off, skidding etc. my previous clio had been in the engine, it would be like I would have used it a bit, it disappeared spontaneously, but whatever the problem is, I think there is a possibility for me to improve the clutch pad roasted clutch pads. BSY's
08.05.2020 18:28 # 3
samet206
I don't want to get into trouble with the same problem in my head. I stood on the slopes for example, it comes to 3500 cycles in 1, and when I plug it into 2, it knocks so much that I can see how the limit breaker is sometimes in traffic when I see the gear lever swinging 50 km at 3500 rpm. I see it difficult, the pressure changed in July last year, but it did not happen for 1 year, the reasons for my problems are that the axle and the pressure pad are not attached to the original one. If there is a creaking noise, the clutch ball bearing can be a problem with them, however, they are likely.
