vehicle stops
08.05.2020 19:46 # 1
akyuz.cagri
Hello. I use 307 1.4 diesel. While the vehicle is in motion, the stop text comes out with the faucet-like fault light and the vehicle is stopping. I pull it over and run it after a few seconds. Then this light goes out and the shame begins to emerge again .. I thought it might be fuel, who has an idea?
08.05.2020 19:46 # 2
ssakyel
Get past, I think the sign that looks like a tap is the engine malfunction lamp. You have to connect it to the computer to find out why it is lit. The reason for the malfunction is understood as such.
08.05.2020 19:46 # 3
gergerli
Could be related to the oil level, is the car missing the oil? Pull over and check the oil level
08.05.2020 19:46 # 4
akyuz.cagri
I have a problem with oil leakage in the engine, yes. I almost complete it in the engine oil..but I am constantly making it. Level is still ideal now. Any other reason?
08.05.2020 19:46 # 5
gergerli
My brother, the light you mentioned is about the reduction of engine oil and reaching levels that cannot lubricate the engine.
08.05.2020 19:46 # 6
ARDADOGAN
Brother, I had the same problem, the car stops, an orange lamp is on, the stop text comes out, 2 - 3 minutes after the stop, the car is running and probably the orange lamp continues to light up then it goes out on its own. Have a 100% solution to the problem, but if what I say is most likely, the fuel pressure sensor cost 120 TL or something
