Vehicle stopping while idling help
08.05.2020 20:21 # 1
orer
Hello friends my vehicle 2013 206 x-line 1,4 hdi diesel vehicle when the engine gets hot, the lights stop pressing the gas when it stops for 1 minute, and the malfunction light burns 2-3 times when I stop and start again, what is the reason or if there is a friend that can help you I'm glad
08.05.2020 20:21 # 2
First of all, welcome to us. There may be many reasons for this. electrovane- flow meter-injectors- diesel pump - diesel filter - turbo - air intake of the fuel system - the fuel you take. So everything we say right now goes beyond your guess, if it didn't change your fuel filter, start with it and change the fuel you get.
08.05.2020 20:21 # 3
orer
goodbye i changed the diesel filter. When the malfunction light was on, we put it in the machine, I took 4 malfunctions, but I can not find it right now, it was 5-6 months ago because there is also a diesel under the quarter tank, and the car does not work.
08.05.2020 20:22 # 4
I understand, did this problem exist before replacing the diesel filter? The problem will be that the diesel pump or fuel system is getting air in one place. Look again at the fault codes. sonerkyl 2017-05-22 13:01:48
08.05.2020 20:22 # 5
Selox
Look at the malfunction codes. There is an sensor of the diesel pump in general and it is deteriorating. I took care of around 400 TL. The problem in me was like stopping, stopping from time to time. Evaluate.
08.05.2020 20:22 # 6
ersin61
My friend, look at the crank sensor. The friend had the same type of malfunction.
08.05.2020 20:22 # 7
orer
thank you guys now, when the brakes are applied, a stop message appears. As a malfunction, the 1st fuel pump says low pressure or something, I say let me clean a tank. Let's see if I found the cheapest solution.
08.05.2020 20:22 # 8
As our friend said, I would change the crank sensor in my teacher and the tank cleaning would be good.
