Vehicle stop but left parking lights
08.05.2020 19:49 # 1
monalos
Hello friends 206 2002 xt gasoline, I stop my car and lock the doors, but the parking lamps on the left side continue to burn, there is no American park in my car and the park is open day and night, the fog has not been up to date, but yesterday I looked at it, the lamps did not find the fault.
08.05.2020 19:49 # 2
American parks are removed and removed. The vehicle does not disconnect power somewhere, possibly an American parking module. we need to disassemble the module and try.
08.05.2020 19:49 # 3
monalos
There is no module already in the signal part, there is a double socket, like a brake light, but it also disassembled it. The same problem has been disconnected and there is no integrated or integrated software.
08.05.2020 19:49 # 4
I don't think it will be software. Lock a thousand doors to the vehicle. Do you hear a sound after 10-15 seconds? Look at it.
08.05.2020 19:49 # 5
monalos
It sounded like it was coming, I was locking the car, the lamps were going out, then it was clicking.
08.05.2020 19:49 # 6
I don't understand, it doesn't have a connection with the coil, but check the fuse box in the engine compartment, I think water may have gotten there.
08.05.2020 19:49 # 7
Cyrus35
Well, if you control the parks on / off button in com2000, if you start the car and do not affect the outside when you open and close the parks from the inside, see from the outside, there may be a problem in the com2000 or signal arm.
08.05.2020 19:49 # 8
fkul
There was a video about the hidden features of pejos on youtube and it was saying that the park was burning, whichever side you parked.
08.05.2020 19:49 # 9
hus3yn
I watched that video on me, but it doesn't explain how it is activated or deactivated?
08.05.2020 19:49 # 10
Cyrus35
If you parked the vehicle on which side you mentioned, it was signaling the side visible on the road, locking the vehicle or pressing the 4 button but I do not think that the trouble of the friend will be u, I remember that this feature was 307 or even I might be in the wrong memory
08.05.2020 19:49 # 11
Alicilik
Bulbs have roles on the bottom plate of the engine fuse box. You have to change the role of the parking bulbs, either from that fuse box or to change the part of that role to a good electronics store.
