vehicle screen is reset
08.05.2020 16:34 # 1
cetin
For the last month, it started to stop working when I started my car in the morning. At one time, the date settings on the middle screen are reset and then the warning sound comes off. "smileys / smiley5.gif" border = "0" alt = "C o nfused" title = "C o nfused" />
08.05.2020 16:34 # 2
Have you checked the status of your mind?
08.05.2020 16:34 # 3
cetin
No I did not, but I will look at the evening. Will we add water ...
08.05.2020 16:34 # 4
[QUOTE = çetin] No I did not look, but I will look at the evening. Will we add water ... [/ QUOTE]
whether you will add different water according to your battery body. Reviews
08.05.2020 16:34 # 5
cetin
Master: How do I know if the battery is running low?
08.05.2020 16:34 # 6
___KxL___
Measure the battery. most likely the flock is about to end.
08.05.2020 16:34 # 7
[QUOTE = çetin] Master, How do I know if the battery is running low? [/ QUOTE]
Once you need to know the age of your battery. If you have watery flux, you should have been maintained at certain intervals. If you have a maintenance-free battery, it is important. If you are not familiar with your battery and want to know its status, all you have to do is to go to a battery and create it with a special device. The device in the battery is intended to measure the performance of your battery during the crank, that is, when it is loaded. Therefore, you cannot perform this operation with any measurement device or any other device. If your battery performance is not good, you will need to change it.
08.05.2020 16:34 # 8
cetin
Thank you very much `` koliva`` & nbsp; master .....
08.05.2020 16:34 # 9
ozaannn
This can happen in cold weather. If the battery is weak,
08.05.2020 16:34 # 10
cetin
full hit .....
08.05.2020 16:34 # 11
06OzGuR06
It is useful to have the battery checked regularly & nbsp; "Smile" & nbsp;
08.05.2020 16:34 # 12
cetin
So which model and how many amp batteries are our 206's better?
08.05.2020 16:34 # 13
06OzGuR06
[QUOTE = çetin] So what model and how many amps of batteries are our 206's better? [/ QUOTE]
We recommend you to use the original battery of your car. .gif "border =" 0 "alt =" Wink "title =" Wink "/> For your vehicle & nbsp; 50 Amps are suitable, but if your car has an extra sound system or something & nbsp; Then install 60 amps. Happy battery is good I use it. "Wink"
06ÖZGüR06 2012-02-06 18:40:58
08.05.2020 16:34 # 14
djchaos
If your battery is dead or the battery connections are loose, if the battery is loose, it can even burn the brain of the vehicle.
08.05.2020 16:34 # 15
ersan
The same problem I had was resetting the time and date when I was working in the morning cold and even writing antipollutoon fault and air bag off. I changed the battery now, thank god there is no problem. I believe you also have a weak battery, I think you will measure the battery and change it accordingly.
