Vehicle's Gas Pump Does Not Work
08.05.2020 17:34 # 1
CuRSe
today we unscrewed the petrol pump completely with my brother-in-law. but it worked when we tried the engine outside, but we still installed the new engine we bought, but the result is still the same. no click when we turn on the ignition. When we measure the socket that goes into the pump, we need to see 12v, while there is no voltage but the float is working. we hear the engine running when we pull it out of the battery directly and naturally the vehicle starts when the starter is pressurized. but when he pulls the cable, he kicks and stabs. I want to help if there is such an event happening to our friends. Thank you in advance.
vehicle 1999 peugeot 306
08.05.2020 17:34 # 2
Insurance?
08.05.2020 17:34 # 3
CuRSe
All of the fuses are intact, I took it out one by one.
08.05.2020 17:34 # 4
[QUOTE = CuRSe] all of the fuses are intact, I took it out one by one, I looked at it and inside the hood there was an electrician relay, we couldn't find it in the diode
The Role ECU should be there. There must be a big black or brown piece towards the back. Officially:
koliva 2013-05-05 22:29:49
08.05.2020 17:34 # 5
CuRSe
Take a picture of my teacher, come here
08.05.2020 17:34 # 6
CuRSe
These are the pictures, my teacher said to the electrician that there will be a 14-15 legged relay, but we did not find it: here it is :(
08.05.2020 17:34 # 7
It does not appear in these pictures. In the second picture, it should be where you hold it with your hand. It must be pinned up there. Isn't there a screwed piece there?
08.05.2020 17:34 # 8
CuRSe
I don't have a teacher ECU already just I got it in the box, I removed it from the rest, the empty box
