VEHICLE RELAY LOW
08.05.2020 19:55 # 1
muharrem76
HELLO EVERYONE
I HAVE BEEN USING FOR 2 YEARS, I HAVE 308 1,6 VTİ GASOLINE & LPG VEHICLES AT THE LAST TIME, THE RELAY OF 690 760 CALIO GENERALLY 700 LATER AND LPG MAKE THIS CONSTRUCTION AND CLEAN THAT IT MAKES THE GAS BUTTERFLY LINKED TO THE COMPUTER LIKE THAT IT HAS BEEN ADAPTED TO THE COMPUTER. THERE WAS NO PROBLEM BEFORE THE PERIOD WAS NORMAL BUT IN THE MORNING THE FIRST RUNNING, THE CIRCUIT WAS HIGHLY AND THERE WAS FALLING TO THE COMPUTER. THEN I DON'T HAVE A TROUBLE PROBLEM BUT I DIFFERENTLY DIFFERENTIZED THE CAR'S TRANSFER LOW BUDDHA WHEN USING LPG SOMETIMALLY SHAKED I HAVE MADE THE VEHICLE I HAVE BEEN TO MAKE IT TO MAKE IT ON I WANT TO KEEP I HAVE BEEN RELEASED TO KEEP I HAVE BEEN TO MAKE IT ON I WANT TO MAKE IT ON THE SURVEY
08.05.2020 19:55 # 2
firstly welcome. throttle settings were checked after throttle adaptation. If the spark plugs are not changed, replace them.
08.05.2020 19:55 # 3
muharrem76
We found it nice, the spark plugs were replaced. I made LPG gas adjustment after adaptation, but I do not know if gas adjustment is done in gas but never in gas
08.05.2020 19:55 # 4
Then try something like this, turn off the lpg system of the vehicle, use it at 150-200 km gasoline.
08.05.2020 19:55 # 5
muharrem76
I understand, tomorrow, I will go on a long road and share it again.
08.05.2020 19:55 # 6
You're welcome, have a good trip.
08.05.2020 19:55 # 7
muharrem76
Hello, my teacher, I used 350 km of gasoline, but there was still no traction, the vehicle handles on the flat road, but something little starts uphill, the car is forced to fall down, I asked a master, the throttle may be faulty, he connected the car to the computer, I used lpg, was writing a rich mixture, then I asked if the cycle was below normal. the throttle can not hold the vehicle at idle, the throttle may be faulty, what I do not understand is that this throttle can be broken, and when the throttle fails, when we connect the computer, does it not have to give a warning or malfunction code that the throttle is defective? I would be glad if you help.
08.05.2020 19:55 # 8
aleyküm salam if it is defective as you said it should give error code, I wonder if the air pressure sensor sensor was checked and there is a leak in the air hoses and manifold. As for the idling problem, it will fix if you find a good lpg master. When you are using gasoline, did you just turn off the lpg from the button. Or did you close the valve in the lpg tank?
08.05.2020 19:55 # 9
TUNAYCAN
If the vehicle is automatic, it makes it from the turbocharger if it is automatic, but if it is from the gear, it makes it from the press pad.
