Vehicle recommendation
08.05.2020 21:19 # 1
bigOver55
I wanted to open a comprehensive topic, but I did not know where to open.
Friends, I have a 2004 golf 5 1.6 fsi vehicle, I did not get a lpg in 148 thousand km.
I say that if I both upgrade the model and make some more appropriate consumption d.
Would you pass 206+ through golf?
I have 206+ chronic problems
Do you recommend 1.4 hdi engine?
1.4 gas + lpg?
Do I regret that I have crazy questions in mind, friends, more or less you understand the problems in my mind.
Please help
206+ would be like 207?
Note: I don't want to add money on it.
bigover55 2019-09-13 01:42:48
08.05.2020 21:19 # 2
Dogukan_3002
If golf was not a safe in 2010 and beyond, I would definitely pass. I've been riding for 10 years. The model is 206+ gasoline .. I do not have the chronic problem that I know in the technical part of the work. the glass frame did not fail, so no. my crank sensor just failed. I guess the room is neglected. Maybe I wouldn't take it off and delete it (maybe I'll wipe it off tomorrow anyway). In short, the cables connected to the engine are incredible quality. I always burn 5 liters in and out of the city. approaching 7 in the cold in winter. Up to this time, there was no problem such as burning fat, blowing black smoke and blowing. Finally, I would like to say to the question of whether I regret it. For example, if you compare it with an astra j, the steering may sound a bit harsh but it is not acceptable enough to give up when we consider the price. Gearshifts and clutch are simply amazing. you may not like the sound of the front doors, but I don't mind. According to its class, it is also very big doors. it is also fine when closing the rear doors and the trunk. the seats are extremely comfortable (I will add a picture to see how other 206+ owners use it) If the rear passengers have problems with the knee distance, the pleasure is in place if you put it forward a little :) when the back seat lies, it will be like amorok when you carry the goods behind it. . I mean, I think he deserves his money based on other models and prices. Let me explain as follows. If I was going to buy it again and my budget was the same, I would buy the gray one this time :) I have been riding for 10 years and I will continue to ride. I guess I have at least 15 more years. I also have never heard of trim sound. No creaking. if you say how would you do your design. wish I had steering wheel height adjustment. I would also add 208 steering wheels :) so the diameter was a little too wide and the positioning angle would look a bit towards the ground. the current original sound system is bad if you like loud and bass music. something else I will add is ignored. To summarize, I don't need to make a difference for 207. If you say I can give it, see the similar models of nissan micra or toyota.
08.05.2020 21:19 # 3
bigOver55
[QUOTE = Dogukan_3002] If golf was not safe in 2010 and beyond, I would definitely pass. I've been riding for 10 years. The model is 206+ gasoline .. I do not have the chronic problem that I know in the technical part of the work. the glass frame did not fail, so no. my crank sensor just failed. I guess the room is neglected. Maybe I wouldn't take it off and delete it (maybe I'll wipe it off tomorrow anyway). In short, the cables connected to the engine are incredible quality. I always burn 5 liters in and out of the city. approaching 7 in the cold in winter. Up to this time, there was no problem such as burning fat, blowing black smoke and blowing. Finally, I would like to say to the question of whether I regret it. For example, if you compare it with an astra j, the steering may sound a bit harsh but it is not acceptable enough to give up when we consider the price. Gearshifts and clutch are simply amazing. you may not like the sound of the front doors, but I don't mind. According to its class, it is also very big doors. it is also fine when closing the rear doors and the trunk. the seats are extremely comfortable (I will add a picture to see how other 206+ owners use it) If the rear passengers have problems with the knee distance, the pleasure is in place if you put it forward a little :) when the back seat lies, it will be like amorok when you carry the goods behind it. . I mean, I think he deserves his money based on other models and prices. Let me explain as follows. If I was going to buy it again and my budget was the same, I would buy the gray one this time :) I have been riding for 10 years and I will continue to ride. I guess I have at least 15 more years. I also have never heard of trim sound. No creaking. if you say how would you do your design. wish I had steering wheel height adjustment. I would also add 208 steering wheels :) so the diameter was a little too wide and the positioning angle would look a bit towards the ground. the current original sound system is bad if you like loud and bass music. something else I will add is ignored. To summarize, I don't need to make a difference for 207. If you say I can give it, look at the similar models of nissan micra or toyota [/ QUOTE]
Hodja, I like my 2004 model car very much. As I said, I want it to burn less. If I buy 206+ gasoline, I will definitely install a tube. 100 percent. I was wondering if it was 1.4 75 hp, what was gasoline, whether it was high or not? I do not think that there will be such a problem in diesel, as it is a turbo like fainting and fainting?
bigover55 2019-09-13 10:53:03
08.05.2020 21:19 # 4
EmSul
get off the golf and ride 206+, it would be bad, go after so much so go corsa or fiesta or even see clio diesel clio 3 hb get or diesel hyundai getz
08.05.2020 21:19 # 5
eran
How much does your car buy?
08.05.2020 21:19 # 6
Dogukan_3002
If you say I wear LPG, I say petrol. I recommend diesel to someone who does not want any lpg. If you ask my opinion anyway, I stay away from diesel and automatic transmissions unless I am German or Japanese. Smile
On the other hand, our friend who said corsa fiesta clio or something, but let's say it based on the budget of 30-35 thousand .. km models whose km is not clear before 2010 comes before, in this range .. in short, 206+ all kinds of better. his head rides comfortably.
Dogukan_3002 2019-09-13 14:10:09
08.05.2020 21:19 # 7
ismailkaya
Do not change your vehicle, call me, take a photo of the cordial engineering or license, send a message to them, they will return to you.
08.05.2020 21:19 # 8
bigOver55
friends 1 month ago, a friend bought golf 5 1.6 fsi vehicle at 176 thousand km for 46 thousand TL, my vehicle is 148 thousand km, I say 47, but I leave it to 45 44. I have a fsi lpg plug, but I don't want to deal with it. I am talking to the nation, everyone is satisfied, I think I will have trouble if there is bad luck. I came to my mind. My manual auto take is absolutely.
08.05.2020 21:19 # 9
bigOver55
I think I will not get more than 2012
can also be exchanged directly
08.05.2020 21:19 # 10
Dogukan_3002
let's see good luck Hug
08.05.2020 21:19 # 11
bigOver55
So you say buy? Big smile I always think that you should follow the road, but not everyone has this chronic problem.
08.05.2020 21:19 # 12
Dogukan_3002
[QUOTE = bigOver55] so do you say get it? Big smile I always think that you should follow the road, but nobody has this chronic problem. They have this chronic problem.
I am not saying, but it is a good alternative in this budget. it does not have a chronic problem, but it does not count quality. nevertheless I have been riding since I got zero for 10 years. now at 130 thousand. I will use it until I die, as I said Clap It is not a fear that it will be broken or drawn. dah dio you are going away LOL I mean, I am happy. Even if you tilt the seat and throw a sack, it carries a good load LOL
08.05.2020 21:19 # 13
bigOver55
[QUOTE = Dogukan_3002] [QUOTE = bigOver55] so do you say buy? Big smile I always think that you should follow the road, but nobody has this chronic problem. They have this chronic problem.
Ahahahahha I laughed so much. May Allah be pleased with your comment. Unfortunately I can't get better at this price. I think that I will upgrade the model and I will save fuel. How is the part about 1.4 hdi maintenance?
08.05.2020 21:19 # 14
Dogukan_3002
Take care of your part, my teacher, take it Wink take the least money in the best condition but .. I say Ietgoyada look. You will travel from morning to evening from now on. There is no fear that I will stay on the road. Continuous throttle to throttle
08.05.2020 21:19 # 15
bigOver55
Thankfully, I brought a gas to a gas that I found one in 65 thousand km. If you can persuade it with my car, let me give you 1 2 thousand TL.
08.05.2020 21:19 # 16
bigOver55
https://www.sahibinden.com/ilan/vasita-otomobil-peugeot-yakit-cimrisi-satilik-732005031/detay
How do you think this tool will get you
08.05.2020 21:19 # 17
Dogukan_3002
valla lpg mounted ones are very fast for sale. diesels are not going fast. take your favorites follow for a while Smile it also makes more sense to sell and buy instead of trading. you go and look at the car you want and get your voice inside Dogukan_3002 2019-09-15 12:20:11
08.05.2020 21:19 # 18
bigOver55
How attractive is the lpg high school? What is the fuel consumption?
I also think it may be troublesome because it is 1.4 and without turbo, but I did not know it.
08.05.2020 21:19 # 19
umydn
You can say fanaticism, brand passion, etc. But now that I have trillion money, my car I used daily would be 508, my car I used for pleasure would be 308 gti or rcz. Peugeot is a very reasonable choice when you compare F / P. After golf, of course 206 will come more uncomfortable, but if you look at it, it will prevail in terms of fuel, finding parts, parts prices 206.
08.05.2020 21:19 # 20
Dogukan_3002
I dropped it to 4.5 liters last month on the out-of-town road in its gasoline state at 100 km. I burn between 5 and 5.5 in the city. Add up to 1.5 liters on these values in winter. Add 2 liters in lpg and calculate according to the gas price of the stations. Smile By the way, the forum is very dead. animate some friends. I am looking at the subjects 3.000 people have read 3 people wrote LOL 206 is a very comfortable car, by the way. as long as you sit in the hall, just spread Big smile I also had the previous case. then in 2010 I bought this + one. You can feel the comfort especially when you go down to buy bread. You don't have to think that nobody would draw or crash. For example, if there is an rcz, you can look back and see if there is anyone approaching. LOL I love 206. The important thing is that you are comfortable. I am also incredibly comfortable in their seats. I go at 7.60 as I go, especially when I sit in the back LOL I'll take a photo as soon as possible. Dogukan_3002 2019-09-15 17:18:17
Page : / 3
