Vehicle pulls to the left
08.05.2020 19:12 # 1
CAN TERTIP
Hello friends, I bought peugeot partner tepee about 1 month ago. There is not even the slightest scratch on any accident in 2000 kilometers. The vehicle has been pulling to the left since the last 1 week. Although the balance balances and tire pressures have been checked, no solution has been found. Do you have any such incidents or can you give advice before? They say there are mechanical malfunctions in the cars. I regret that I received
08.05.2020 19:12 # 2
sezar206
Maybe the rim is bent. Take one of the rear tires and give it a try.
08.05.2020 19:12 # 3
talip206
I think it's about tire or rim. The wires inside the tire or the rim may be distorted
08.05.2020 19:12 # 4
Ahmet_ach
not related to tire and rim, if the rim is tilted, the vehicle will make trim, do not turn left, do not adjust the rot balance setting elsewhere.
08.05.2020 19:12 # 5
ibrahim
I had the same problem. It was said that the curves of 4 tires are different from each other. I changed the front 2 tire and the problem got better.
