vehicle oil pressure light and engine warning light
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
02.11.2021 18:47 # 1
djwolf
Hello friends, as of yesterday, I bought 208 vehicles from someone and when I put it into the appraisal, there was something different in the engine, but it could be because the oil was put in more than 4 liters and it was throwing white smoke, and the owner said yes yes there is absolutely no problem in the engine, I showed it to my engine master. He said no, but the expert still said, show Fatih Peugeot (Ankara), and when I showed him there, the master said the engine is normal, so we drained that 4 liters of oil and put the necessary oil on me, so I bought the sale, but after I took the sale on me, the engine warning light was on when I drove the first car. When I asked why this was with me, he said that the oil has just been changed, he said, and after he left it, the oil pressure light came on while the vehicle was idle and the stop sign appeared. There is also a photo of it, but I don't know how to post it here
03.11.2021 08:43 # 2
ismailkaya
What is the exact engine type of the vehicle you bought? 2.4 16v 90 HP. is it?
04.11.2021 00:08 # 3
djwolf
1.0 vti
12.11.2021 23:04 # 4
Puger208
First of all, hello, your car's km. what? And have you ever had a timing belt changed before?
16.02.2022 16:45 # 5
cagoto3535
Sir, why did you ask about timing belt? The timing belt has been changed for me, it's been 5-6 months, it seems like the engine is running badly, I also have a peugeot 208 1.2 active.
16.02.2022 16:57 # 6
Puger208
My master, first of all, the reason why I ask about the timing belt is that the timing belt of our vehicles is called an oiled timing belt, that is, the timing belt rotates in the engine oil. If the vehicle mileage is high, an average of 100 thousand km or more and if the timing belt has never been changed, small pieces of the timing belt may clog the mouth of the oil strainer. This may be your friend's problem, in my opinion, the pump may function as a pump and the lamp may turn off because the speed increases and the pump works more powerfully when he presses the gas. For this reason, crankcase cleaning is recommended for 1.2vti or puretech vehicles when the timing belt is changed. In your trouble, the vehicle may have jumped to the cent while the timing belt was changed. I recommend that you have a vital issue for the timing engine urgently checked 🖐 🏻 respects
