Vehicle misfire in motion
08.05.2020 19:43 # 1
KidCabrio307
Hello friends,
I have an integrative situation. I would be very pleased if you give your opinion. They could not help in the services. Because they couldn't detect the error. In fact, all they did was just connect the car to the computer and look at it.
My vehicle is 307 2.0 180 HP RC Engine. 2005 Model. LPG has been installed before. It was later removed. I am now using gasoline. The engine fault light is on when my vehicle is on the road from time to time. The engine seems to be singing. The vehicle is suddenly cut from the gas. He comes to himself right after. Once again, he went like this on the highway with 110. Frankly, it scared me a lot. I immediately took the error to a private service. There were no registered errors on the computer. I think I made it look 3 times at different times. There was no problem on the computer every time.
A few days ago, the traffic light came on again as I stopped in congested traffic. The engine stopped on the road. This time I was in the middle of traffic. He did not start in a few tries. After waiting for 2 -3 minutes, when he tried again he came to work. After a few kilometers, he stopped again. Then he came back to himself.
The vehicle was going faster at first. After several kicks, it seems as if he reacts less to gas. Accelerates slower than before. Sometimes I see the Antipolition Fault error. I don't know if the same reason for this kick is different.
My problem is to summarize that the fault light flashes while the vehicle is in motion and the vehicle kicks up as if the ignition is turned off and on. What is your opinion?
08.05.2020 19:43 # 2
ssakyel
Get well. My friend had experienced a similar fault in the skoda car. The vehicle was kicking while it was in motion, it was cutting the gas. The computer did not show a malfunction, and only when the malfunctioned, the malfunction light was on. Then one of the coil came out malfunctioned. I think about the ignition system. Experienced friends are sure to help.
08.05.2020 19:43 # 3
KidCabrio307
Thanks. While reading a little, I read that it might be related to the ignition system elsewhere. I will look at it at the first opportunity there. In order to record the error in a master, he added a small apparatus to the socket where the computer was connected, and said that the error can be recorded with that apparatus. I also hope to catch the error from that apparatus.
08.05.2020 19:43 # 4
As you said, this kind of problem, a situation related to the ignition system probably seems to be related to the coil that our other friend said.
