Vehicle Maintenance
08.05.2020 18:02 # 1
efesbright
friends it was almost 18000km to get my car under maintenance. But I do not use the tool that is currently, I could not get maintenance due to financial problems. I did not want to have periodic maintenance when the bidet gave 500tl price, obviously I would have two questions, I just wondered why.
1- The vehicle vibrates during the take-offs and 2nd gear changes. oil level seems to have dropped by 0.75lt. Could this tremor be due to oil? Is it normal for the vehicle to reduce oil between 0.75lt and 1lt at 18000 km? should i complete
2 - and the air filter did not change, of course, the sound is bad from the engine, loud noise occurs because of the air filter?
3- Why don't you ask, please do not say something like maintenance, the point I wonder is whether these problems are due to the air filter and oil, or the engine is old.
4- Another question. timing change at 180000km 1.4 hdi 207 vehicles. Can I handle up to 175 vehicles at 169,000 km now?
5- Can you drive the vehicle without doing these maintenance? Does it cause worse things? After all, peugeot writes a maintenance at 20 thousand km under normal conditions.
I have a little skit in between. When I hold the traffic insurance 1078tl, I really couldn't get the car.
08.05.2020 18:02 # 2
EmreOz
I think it is nice even if it is still shaking. Brother, you did not change my fat, if you look at it, it is a pity to the vehicle. I hope your troubles will pass. Cost with Care There are many different material items psychologically ... If you ask my opinion, the situation may be worse.
Shivering .. May be from oil
When it comes to the sound of the engine, lift a car, soot accumulation in egsos and the line until the last muffler may be rotten. emreöz 2013-11-03 01:50:24
08.05.2020 18:02 # 3
It is difficult to say when you need to have maintenance done without knowing what kind of oil you are putting on. Under normal circumstances, it is time to take care of your vehicle. I am not likely to cause problems with triggers, but this is the trigger, even if the next day you change it, there is a slight chance of causing problems. My advice, put your car in a little maintenance. Replace the oil + oil filter and air filter and the fuel filter if it has not been replaced for a long time. I think you will see the difference. 0.75 liters of oil reduction seem normal under these conditions.
08.05.2020 18:02 # 4
efesbright
Thanks for the friends comments. When I solved the transmission problem, the master said that we would change the engine ear in the next maintenance. do you think the motor ear will make this tremble?
