Vehicle maintenance
08.05.2020 16:54 # 1
yigiteroglu
Hello everyone, guys. My vehicle in my signature was maintained between 150,000 and 153,000 km, but probably 153,000. My car is currently at 161,000. In the past maintenance, air filter oil filter pollen oil change, timing set change, circulation pump change etc. things have been done. In the beginning of August with my vehicle, I will go to Alanya from the long road. What maintenance should I do before you go and what should be the brand of the materials I will use? Like everyone else, I want to use the best quality of oil at night and I am planning to add boron engine oil after the oil change.
08.05.2020 16:54 # 2
yigiteroglu
Here is my car 1999 model automatic lpg li 206
08.05.2020 16:54 # 3
tellotello
I think an oil changes in 10000. You may need to replace other filters, ie air and pollen filter. If the fuel filter changes at 30000 km, there are more. Other than that, make routine checks, check the amount of water, have the air conditioner checked or something before you go. Other friends will perhaps provide more detailed information. Have a nice trip & nbsp; "Smile"
08.05.2020 16:54 # 4
yigiteroglu
Thank you very much for your valuable comments.
08.05.2020 16:54 # 5
yigiteroglu
Friends, what should be the brand number of oil?
08.05.2020 16:54 # 6
[QUOTE = yigiteroglu] Friends what should be the oil brand number [/ QUOTE]
5W-40 from one of the known brands (Castrol, Mobil 1 ... etc) is ideal.
08.05.2020 16:54 # 7
yigiteroglu
Thanks koliva :)
08.05.2020 16:54 # 8
EErgul
Take a look at the cooling system and look at the radiator. change it even if it looks bad. my tongue burned last so I wanted to remind you about it. the weather does not forgive too hot mistake.
