vehicle lowering aid
08.05.2020 16:26 # 1
etiket53
friends 2001 model 1.4 206 I got 17 wheels on my car .. I wanted to lower it but the sport spring did not reach the lowness I want and amatsor sounds sound, it sounds like we need to cut amatsor.
08.05.2020 16:26 # 2
djchaos
Don't hesitate, the shock absorber is not the sound from your sports springs. You should come with the springs with the sports springs. You should put the hoses on the springs and assemble it. We have 18 inch rims and sports springs.
08.05.2020 16:26 # 3
golge_oyunu
If the springs you use are around 5cm, you should also replace the shock absorbers, so that they do not buy suitable shock absorbers for their springs .... & nbsp;
08.05.2020 16:26 # 4
etiket53
I have already removed the shock absorbers from the eye, in a run that will stop buying new ones.
08.05.2020 16:26 # 5
djchaos
I heard the shock absorber disconnection for the first time. If you are going to buy a new shock absorber, there are sports shock absorbers, I recommend you to buy them as a team.
08.05.2020 16:26 # 6
dukenukem82
things will change when the new compliant is obliged to compete at 17 206 daed
08.05.2020 16:26 # 7
pachito
amartisor & nbsp; does not cut & nbsp ;, amartisor wedges cut halfway, but watch out, :), because they usually do & nbsp; amartisor & nbsp; cutting is done when cutting the original springs, but I definitely don't recommend & nbsp;
08.05.2020 16:26 # 8
sosyete_60
If you use 15 WHEELS & nbsp; AND 3.5 CM SPRING & nbsp; TAKARSAN BECAUSE NO SQUARE SUSPENSION BECAUSE IT WAS IMMEDIATELY IMMEDIATELY THROUGH THE TORSIONS.
08.05.2020 16:26 # 9
ose
You did not fully disclose the situation. My only advice to you is don't cut the spring, shock absorber or chock.
08.05.2020 16:26 # 10
peugeotefe
If you want your vehicle to fall the way you want, press the springs to make it more beautiful than the sports spring.
08.05.2020 16:26 # 11
ike
how do we press the springs?
08.05.2020 16:26 # 12
Ucyuzalti
What is the difference, apart from cutting the bows?
08.05.2020 16:26 # 13
MagicPerformance
If you are not going to use it at very limits, you may not be going to scissor-like movements, but shortcut / pressing is not a healthy solution.
08.05.2020 16:26 # 14
yavuz25
[QUOTE = Three Hundred] Six Unlike cutting the bow, what's the plus? [/ QUOTE]
shortens the length of the broadcast because they restrict the amount of oscillation by pressing the springs. So the distance between the pods decreases. The difference from the spring cut is a little safer. img src = "http://forum.peugeotturkey.com/smileys/smiley2.gif" height = "17" width = "17" border = "0" alt = "Wink" title = "Wink" />
08.05.2020 16:26 # 15
Ucyuzalti
But because of the yawn share, doesn't it come back to the same & nbsp; "LOL" seems to be better
08.05.2020 16:26 # 16
yavuz25
The stretch of numerator decreases, of course. After that, it hits the bumps in a row. "Wink"
08.05.2020 16:26 # 17
Ucyuzalti
I don't have 2 daddy boots like me, satin on the front, no need for such works "LOL" I put my aunt overnight there is a little weight problem 130 kilo car side stood aga officially said I still get behind you & nbsp; "LOL" "LOL"
