Vehicle intake
08.05.2020 20:15 # 1
monalos
Hello there are 206 gasoline vehicles in the rain, the vehicle gets water right front and right rear mats become lake, it was raining today, I went down, I looked at it from the bottom of the door wickers, it leaks in. The car is standing bent to the right. Should I change it, starting from my upper front part of the ceiling side plastic and ending in the half of the back door, it seems to me that the most logical thing is to change the side channel and try to get your comments. monalos 2017-03-17 22:28:40
08.05.2020 20:15 # 2
monalos
http://www.peugeotmarket.com/peugeot-206-tavan-kenar-lastıgı-orjınal,pr-2078.html
This is the piece I say is number 7 monalos 2017-03-17 22:32:00
08.05.2020 20:15 # 3
talip206
The problem is 90 percent door interior trim insulation. If the speaker is changed, the isolation paper inside is torn. If there is no tearing in the tire, it is very expensive to make no effort.
the https://forum.peugeotturkey.com/forum_posts.asp?tıd=43607&title=206-su-konusu-bir-cozum-bulalim-arkadaslar-lutf talip206 2017-03-17 23:52:38
08.05.2020 20:15 # 4
monalos
I torn the interior door trim 2 years ago while doing the under door leds but there was no problem for 2 years now why started
08.05.2020 20:15 # 5
talip206
[QUOTE = monalos] I teared the interior door trim 2 years ago while doing under-led leds but there was no problem for 2 years now why started [/ QUOTE]
The direction of water has changed over time. Normally, any kind of water enters the door. The important thing is that the water does not come in but out. But when the insulation is torn, it takes water.
08.05.2020 20:15 # 6
talip206
It is such a dirty thing that you can not always detect it, sometimes it did not take it if it was raining, but it was watering thinly. sometimes it's just the opposite. Don't waste your money, teacher, the source of the problem is probably where I said it.
08.05.2020 20:15 # 7
monalos
Well, if I have her zero and paste it
08.05.2020 20:15 # 8
talip206
[QUOTE = monalos] Well, if I take her zero and paste it [/ QUOTE]
You do not need to buy anything special, you can buy insulation material and stick it. There are building markets. It helps both in sound insulation
08.05.2020 20:15 # 9
dejawu1978
talip206 halal you made a point shot to the problem officially .... when there is no door isolation, it is highly likely that water will enter inside.
http://i.hizliresim.com/r39env.jpg
dejawu1978 2017-03-18 18:46:42
08.05.2020 20:15 # 10
onlycihan
I had the same problem
in https://forum.peugeotturkey.com/forum_posts.asp?tıd=43424&title=206-aracim-su-ic
On page 2, there is a summary of the actions I have done to solve the problem.
