Vehicle Goes By Skip
08.05.2020 20:59 # 1
kayaca
friends I have 206 vehicles
tell me i have a problem when the car is going to the bump, it is going to skip it, you will eat one side of the wheel and when it comes to it, it does like the horses out of the space, it doesn't feel like it presses the car to the speed, I think it was when I picked it up, I said it was made from the wheel, I changed the wheel again, I said again I was doing it from the rim, I changed it from the wheel, I changed the wheel again, I said again, I was doing it from the rim, I changed the wheel, I said again, maybe I made the gearbox I lowered the gearbox and made it again. Why else can you do that?
one of our friends said that the subject vibrates in 2 gear, the gear vibrates in the low rpm, it makes me shudder in the low speed as well.
08.05.2020 20:59 # 2
Carrier - check springs and shock absorber, bro. There is a high probability of being a love. Check the hub ball.
08.05.2020 20:59 # 3
Selcuk55
If there is curvature in the axles, it makes space if the tulips at the end of the axle are empty. Selçuk55 2018-08-16 20:25:57
08.05.2020 20:59 # 4
kayaca
Can't a mechanic see them, does he not understand that rotz while checking his arms or something?
08.05.2020 20:59 # 5
Brother, here is the mastery. Every master cannot see these mistakes even if they are small.
08.05.2020 20:59 # 6
kayaca
[QUOTE = sonerkyl] brother, here is where the mastery starts.
I understand that the president will take him to the service then let us see to see what the situation will be
08.05.2020 20:59 # 7
GokhaN
jumping from the axle, as the selcuk said, has nothing to do with jumping rod
08.05.2020 20:59 # 8
onurrr41
The last time my vehicle did so, the axle was cut, it was jumping at the first stage, after 15 km I stopped to check what happened. The car made a voice called "garççç" while I thought it was going to continue. The axle gear was well stripped, so we had the vehicle pulled.
