Vehicle gets water EMERGENCY |
| 08.05.2020 18:46 | # 1 |
| 08.05.2020 18:46 | # 2 |
Check the location of the antenna, that is, the interior lamp. The glass can not be repeated again with silicone with the glass bonding silicone. |
| 08.05.2020 18:46 | # 3 |
I get it, but how does it go down from the middle down there is no indication, the middle part of the flooring of the antenna is there, I checked the edges, nothing is moderate wet
| 08.05.2020 18:46 | # 4 |
It drops to the place where the full gear is, it flows down when it is full.
| 08.05.2020 18:46 | # 5 |
Thanks for your information, I will definitely look and give you nothing, but as I said, there is no indication, neither your gear is there, nor the lamp is interesting or there is nothing on the side of the lamp. I looked at the channels inside the hood, poured water, no flow, no problem, thank you for your help already
| 08.05.2020 18:46 | # 6 |
I'm talking about the interior ceiling light inside the cabin just above the gear lever. http://forum.peugeotturkey.com/forum_posts.asp?tıd=26438 http://www.peugeotmarket.com/peugeot-206-tavan-ıc-lambası-orjınal,pr-2139.html |
| 08.05.2020 18:46 | # 7 |
I understand, the place you are talking about, my brother, there is nothing there, but I still want to disassemble it and keep it in mind. Is there a grill where the windscreen is located? I didn't look, do I have to remove the wipers there?
| 08.05.2020 18:46 | # 8 |
There is also a plug where the pedals merge with the engine compartment. |
| 08.05.2020 18:46 | # 9 |
ok, thank you very much, I will give them all, I hope they are not very detailed.
| 08.05.2020 18:46 | # 10 |
KILIC |
Sir, you checked the car for water reduction or something.
| 08.05.2020 18:46 | # 11 |
In my vehicle, both the antenna gets water from the place and the water drips on the right side when the air conditioner is on. Probably your problem is like that
| 08.05.2020 18:46 | # 12 |
There is no water extraction, I checked, I suspect from the air conditioner, there was nothing on the right side, I just noticed, but I just looked at the wet edges of the flooring, but there is nothing. Could the hose of the air conditioner go through the bottom or something?
| 08.05.2020 18:46 | # 13 |
90% air conditioner because there is no problem when I don't turn on the air conditioner. But when I open it, the dripping starts. In the same way, when it rains, water comes from the antenna. If our problems are the same, look at these two places, I think
| 08.05.2020 18:46 | # 14 |
the wipers might be picking up from there. If there is a channel, if there is a blockage, it throws water.
| 08.05.2020 18:46 | # 15 |
Look at the water drain or gaskets of my teacher. Look at the heater core and gaskets on the back of the torpedo and it was the same problem. water was not coming from the sunroof, but the interior of the vehicle was turning into the lake. I'm not saying it from there, but if you believe your vehicle will not get water from another place, I would say check / check the places I said.
| 08.05.2020 18:46 | # 16 |
So, is the water drain under the floor of the rug? If so, I'll have a floor, but my first priority is to see if the grills of the windshield didn't look there, will I remove the wipers?
| 08.05.2020 18:46 | # 17 |
Hello friends, I also have 307 dims in the left corner of the car, but the seat is getting wet, I wonder if you can help. Thank you,
