Vehicle gets too knocked
08.05.2020 17:17 # 1
cnrars
friends I have 206 vehicles, 2006 model, I have 15 winter lassa tires and 15 steel wheels on it. I am generally satisfied with the vehicle, but my vehicle is knocked over, for example I feel a lot when driving 90-100 km. For example, some roads are knurled, you know, it is really hard to keep the vehicle on such roads, so that there is no slippage. slipping left and right, is this normal or is there a problem with my vehicle. The cause may be, the tires have 30 air and winter tires. I wonder if the wheels are heavy, the car cannot recover itself?
08.05.2020 17:17 # 2
Bugra
Don't worry about all the problems you're talking about.
those jagged roads, especially if the bidet is in the bend, toss out.
pulls from the front. Since the front of the vehicle remains light when driving uphill with the vehicle, if the vehicle is wet, especially if it is wet, the vehicle pulls paws and it feels as if it is going to the left and right in the direction of the holding wheel. & nbsp;
08.05.2020 17:17 # 3
eroglu
I have 14 rims, my tires are old, the front set (swing and tie rods) are broken, so I bought michnelin laastik for 4 seasons, I also made the front set so much better now, but still our cars need to be careful in bends and wet, so the important thing is the life, accident-free and driving without punishment ...
08.05.2020 17:17 # 4
cnrars
It doesn't seem very normal to me, though. Could it be something about the rim or the tire? when climbing uphill, if there is light water in the grounds, I cannot recover the front. There is no abs in the car, by the way. I use lassa snoways. There were petlas I bought for 90 liras before, but there were no 15 rims, there were normal rims, I wouldn't slip so much, I even got out of the slope where the nation couldn't get out. & Nbsp;
08.05.2020 17:17 # 5
falan
If there are 3-4 people in the vehicle, it is more comfortable on the ground and does not make tossing on the roads. but you can still be comfortable for a tie rod balance or a stop .. if we compare the old tire to the new tire .. you will probably get a lot of air in the new tires .. reduce the air a little ..
08.05.2020 17:17 # 6
cnrars
I sent an email to Lassa yesterday, because my tires are new and very slippery. They called today, they had to examine the tires. & Nbsp; I said it was a Snoways model, they would return within 20 working days. & nbsp; However, since the original tire size of the vehicle is 14, it could be a problem because it is 15. Is something like this possible? The original of the vehicle had normal wheels and 14 wheels. Since mine was 15 steel, it could slide and skid. Is such a thing true?
08.05.2020 17:17 # 7
Mert Pekcan
Wide base rubber and nothing will stay if you press :)
08.05.2020 17:17 # 8
Bugra
[QUOTE = cnrars] I emailed Lassa yesterday, because my tires are new and very slippery. They called today, they had to examine the tires. & Nbsp; I said it was a Snoways model, they would return within 20 working days. & nbsp; However, since the original tire size of the vehicle is 14, it could be a problem because it is 15. Is something like this possible? The original of the vehicle had normal wheels and 14 wheels. Since mine was 15 steel, it could slide and skid. Is this something right? [/ QUOTE]
my teacher, this work is not resolved. Either shoot the situations you mentioned in the video, let's take a look here, or go get a master, test it and use it in the car.
& nbsp; what anticipation did you mail the guys?
08.05.2020 17:17 # 9
cnrars
Lassa called and said there might be a problem with tires getting stiff in cold weather for a long time. In my car, he waited almost 25 days in Göral's parking lot and to the coldest days of Ankaran. & Nbsp;
I mean without any other skid, if the ground is wet at high speeds (after 90 & gt;) the steering If the ground is not very good when I leave it, the vehicle slides left and right. >
By the way @MertPekcan tires are already wide base. (185 * 55 * 15)
08.05.2020 17:17 # 10
_semihk_
my brother makes wide base tires plunge.
08.05.2020 17:17 # 11
cnrars
friends yesterday I looked at the air of the tires, I was not looking for a long time, 37 front, 36 rear :) I wonder why these problems can be. How many should be normal, 15 inch tires (front and rear)
08.05.2020 17:17 # 12
baroff
How many psi should I have on the tires, I have 30 psi
08.05.2020 17:17 # 13
tellotello
[QUOTE = cnrars] friends yesterday I looked at the air of the tires, I was not looking for a long time, 37 front, 36 rear :) I wonder why these problems. How many should it normally be, 15 inch tires (front and rear) [/ QUOTE]
I feel a little too much. I am printing 32, it is generally not a problem. When you open the driver's door, it should be written between the hinge and the door. I print a little less than the values there. Usually the masters always say 32 bass. You can understand that the tire air has been pressed more than it should have been when the vehicle bounced in the pits and the normal ride or something. & Nbsp;
08.05.2020 17:17 # 14
Bugra
[QUOTE = tellotello] [QUOTE = cnrars] yesterday I looked at the air of the tires yesterday, I was not looking for a long time, 37 front, 36 rear :) I wonder why these problems. How many should it normally be, 15 inch tires (front and rear) [/ QUOTE]
I feel a little too much. I am printing 32, it is generally not a problem. When you open the driver's door, it should be written between the hinge and the door. I print a little less than the values there. Usually the masters always say 32 bass. You can understand that the tire air is pressed more than it should be when the car jumps in the pits or the normal ride. & Nbsp; This is the size of the original tire's air pressure in size 14. The tire size of your friend is not orgy. Also, the friend doesn't talk about the tire sizes, but only the inches of the rim. so the base width and cheek size are not clear. but no matter what I think is 37-36 airless tire & nbsp;
08.05.2020 17:17 # 15
cnrars
usundaQUOTE=bugrature
my teacher is the air pressure measure of the original tire in size 175/65/14 between the door. The tire size of your friend is not orgy. Also, the friend doesn't talk about the tire sizes, but only the inches of the rim. so the base width and cheek size are not clear. but in my opinion, thank you for your response to the 37-36 airtight tire & nbsp;
. the tire size of the vehicle is 185 * 55 * 15, 32 is now on 4 tires, we will look at the evening is there any problem (:
08.05.2020 17:17 # 16
falan
The first place you should look was the tires ... I have the same tire in me. I'm printing 30-31 in the city .. 32-33 on the long road.
08.05.2020 17:17 # 17
loiz
My friend, you carry life on those vehicles, go to a solid tire man, check the torsion settings of torsion of the tire air, let him take care of him like a man. ? 206s are already a festive car with the original suspension suspension, over 90 on wet ground, especially with snow tires, we are entrusted to God, be careful.
08.05.2020 17:17 # 18
istanbullu_3886
as a tire, I am on the wing where the tire air is high
