vehicle gas cut 306 xr
08.05.2020 14:03 # 1
If you know friends, please inform. I have 2000 model 306 XR, the vehicle has a sequential system Lovato brand LPG, but when it comes to both LPG and gasoline, the vehicle cuts gas and the engine does not matter regardless of fuel and slows down after 10 or 15 seconds, the vehicle improves by putting it forward and the speed indicator does not work when the vehicle starts to do so. It starts, after repeating a few times, the vehicle gets better and the speedometer comes back to itself. Vehicle automatic gear 306 xr
I am waiting for your answers :(
08.05.2020 14:03 # 2
hasimayaz
Since it does both in LPG and gasoline, it is necessary to examine common points. If it were just cutting the gas, it would be necessary to look at other points, but the speedometer would stop working and point to the ECU.
The ECU is of course the priority in such a malfunction. Secondly, the transmission Automat should also be checked. Due to the fact that the tachometer sensor is not wired but electronic, there is a high probability that it will malfunction.
Have you ever got the car connected to the computer ?? Is there any error log `u falling on the computer?
08.05.2020 14:03 # 3
No, brother never connected to the computer, but after the engine started to cut off the gas, the light indicating the engine mechanical malfunction on the vehicle's dashboard starts to flash, and the stop light on the indicator lights up after the gas cut ends and the speed indicator comes on, but the stop light goes off, but the engine mechanical malfunction continues to light.
08.05.2020 14:03 # 4
onderoto
brother definitely show the crank speed sensor
Likewise, one of my client's complaints was solved in this way.
With 90% chance, this piece will fix the problem.
08.05.2020 14:03 # 5
So, how many times does the average explode?
08.05.2020 14:03 # 6
Ismail
Get well soon..
08.05.2020 14:03 # 7
Thank you bro
