Vehicle Fuel Problem 2
08.05.2020 21:03 # 1
demirtaskerem
1 question) Good night. I had a question recently regarding the fuel problem. Now I have tried my car and it turned out that the account of 36 cents burned in km, because I do not understand too much, I do not know if it is too little or not. Can you give information
In addition, I made the calculation as follows: While I was 148174 km, I bought 30 TL of gas at a price of 3.56 and 8.420 liters and I traveled 83 km with this gas. I got my car peugeot 206 2001 model system, when I heard the warning sound, I bought it again in case of loading the gas. Also my gasoline
2 questions) I bought 6.96 TL 50 TL gasoline about 19-20 days ago 7,180 liters and today it is over just using it while working ??? I would be glad if you answer separately
08.05.2020 21:03 # 2
KvncKR
1) If your vehicle is 1.4, these values are normal in urban traffic. It follows that the temperature of the air can be extended by 8-10 km according to the traffic situation, depending on the humidity, the quality of the fuel. It should not be forgotten that even the air of the vehicle affects the fuel business. There are things that have more than one reason, even when there is a heavy load on the trunk, it affects the fuel of the car.
2) When you start your car, it runs on gasoline engine, when it reaches the ideal temperature, it changes to Lpg system. In winter, the working time is long in gasoline (due to the cold it warms later). Move it 45 seconds after running now, this time is as good as 90 seconds when the snow is winter.
08.05.2020 21:03 # 3
demirtaskerem
1) Yes, my car 1.4. Thank you, I'm glad the gas condition is normal.
2) My problem with gasoline is this teacher 50 TL = 7.180 liters of gasoline is normal as soon as 19-20 days? Although he only used it while working?
08.05.2020 21:03 # 4
GokhaN
[QUOTE = demirtaskerem] 1 question) Good night. I had a question recently regarding the fuel problem. Now I have tried my car and it turned out that the account of 36 cents burned in km, because I do not understand too much, I do not know if it is too little or not. Can you give information
1) normal burns
2) normal
08.05.2020 21:03 # 5
demirtaskerem
I read in some places, and some people talk about using 50-100 TL of gasoline for 2-3 months, so it spends a lot of gas on my head.
08.05.2020 21:03 # 6
GokhaN
[QUOTE = demirtaskerem] I read in some places and some people talk about using 50-100 TL of gasoline for 2-3 months, so this is why I spend a lot of gas on my head. [/ QUOTE]
believe in what you read and see the history of 7 liters of gasoline you do not go to the teeth of the vehicle anyway
08.05.2020 21:03 # 7
demirtaskerem
Thank you, Gökhan.
08.05.2020 21:03 # 8
GokhaN
[QUOTE = demirtaskerem] Thank you, Gökhan. [/ QUOTE]
You are welcome, after you have taken care of the car, whatever burns it, not every vehicle will burn the same. Maintenance history usage style, engine's performance, tire etc. Everything affects the fuel.
08.05.2020 21:03 # 9
x571
It is normal if the city burns 10-11 liters per 100 km. It is normal if it burns between 80-90 and 6 liters outside the city. these are lpg values. If you say less, the cycle time will not exceed 20.
08.05.2020 21:03 # 10
demirtaskerem
x571) I have a normal LPG incineration of 30 TL = 8.420 liters Lpg. 83 KM I went to the city road.
It was a gas event, I bought 50 TL 20 days ago, which seemed to be burning up today, but it was normal.
08.05.2020 21:03 # 11
Levent206xt
My brother has gasoline. These vehicles do not measure from the buoy. As a result of the km, the gas gauge will drop, the gas will fall as you go. Buy 50 TL of gasoline will be higher than when you bought it.
08.05.2020 21:03 # 12
demirtaskerem
My teacher Levent, yes, I am aware of this situation. However, at the end of the 19-20 days I mentioned, the vehicle does not work at all, it stays starting, there is no ignition, and I understand that it is over in this respect. That's why I say he eats a lot of gas. Everyone knows that the prices of gasoline should be above the high quarter tank, but for a healthy use, everyone is only asking for a 100 TL gasoline quarter tank.
08.05.2020 21:03 # 13
Levent206xt
How many kilometers do you make on average in 20 days
08.05.2020 21:03 # 14
demirtaskerem
I have not calculated exactly this before, my teacher, as of today I have noted the amount of KM and the amount of gasoline I bought, and I will look at how many KMs I have used until the next gasoline.
However, I have been using my car every day, even if it is almost short in the city, on average (estimated) I made 200-300 KM in 20 days. I made contact on-off 3-4 times a day. The sequential system, meanwhile, only uses my vehicle when running.
08.05.2020 21:03 # 15
reKor
gasoline consumption seems a bit too much hodja
