Vehicle Fuel Problem
08.05.2020 21:04 # 1
demirtaskerem
Good candles to all of you.
About a month ago, I had mentioned a problem related to the fuel problem and you made a suggestion to calculate by km from here, thank you. My vehicle Peugeot 206 has an in-line system. Last month, I bought 100 TL = 14,270 Liter gasoline on 18.10.2018. Today is over 1 month was enough and I have traveled 584 KM. Do you think it is normal for it to finish in such a time according to its use while working? I would be glad if you could help.
08.05.2020 21:04 # 2
HasGur
[QUOTE = demirtaskerem] Good oil lamps to all of you.
If you have traveled about 20 km a day, if you have run a cold engine 2 times a day, it can be said normal because of 3 km of gasoline used every day. The fuel consumption of the cold engine is almost 2 times higher due to the rich mixture adjustment, with today's gasoline price it costs 1 pound per km. If you want to evaluate it fully, when you run it in the morning, you should immediately move and measure how far you have traveled until you get into the gas. Reducing the transition temperature to gas reduces the gas consumption a little, but it is not worth the trouble and it is not worth to say that LPG is advantageous especially for the vehicles that make less km like yours in the winter, even if the diesel price is much more than 1 liter due to the price of diesel that is equal to the price of gasoline. no longer it is. I think the popular vehicles in the coming years will be vehicles with gasoline engines such as 3 cylinder 800-1000 cc 60-70 HP!
Hasgör 2018-11-20 03:43:12
08.05.2020 21:04 # 3
ismailkaya
You said you bought 100 TL gasoline and 584 km how did you do it?
08.05.2020 21:04 # 4
x571
Calculate according to him that 1 tank of gasoline goes 1 year. The tank is also 60 liters.
08.05.2020 21:04 # 5
Karacocuk24
[/ QUOTE] There is water like normal, when you start the vehicle, you can get out of the ramp directly with the cold engine.
