Vehicle Does Not Go To Gas
08.05.2020 18:52 # 1
themurat54
When my friends have been running the car for a few days, they work directly on gasoline and do not switch to gas. I spend it manually.
I also get the warning sound when gasoline is low. I put gas in the car but there is a problem because there is not enough gasoline or because the car does not switch to gas, so I do not understand whether it gives warning sounds.
08.05.2020 18:52 # 2
themurat54
Nobody answered, but let me write my solution for what happened to the same.
The water that got into the LPG brain opened the brain, washed it with thinner and dried it with air, but it did not recover immediately, but after 10 minutes, it returned to normal.
I guess the water was dripping on the hydraulics next to the brain in the form of drops, I guessed through the plastic of the windshield, I tried to pour water into the windshield. So I had to spend there to prevent water Confused
