vehicle does not accelerate
08.05.2020 19:16 # 1
Erol Yilmaz
Hello friends; I have a 2004 model diesel 307. I have been using my vehicle for about 3 years. There is a problem in the vehicle that I could not understand for the last week. vehicle acceleration has changed. The vehicle does not pull on the ramps that I took with the 3rd gear. I feel that the car is not going at its former speed on the straight road. I wonder what could be the problem? Cry I would appreciate if you help. thanks in advance ..
08.05.2020 19:16 # 2
Erol Yilmaz
No one can help friends?
08.05.2020 19:16 # 3
pusutr
Have you checked the turbo hose?
08.05.2020 19:16 # 4
ismailkaya
If the turbo does not go and the vehicle does not go, it may be 120.000-150.000 in a few thousand years.
08.05.2020 19:16 # 5
Erol Yilmaz
MY VEHICLE I HAVE NOT DONE AT 140 THOUSAND YET. I AM NOT EXPERIENCED ON THESE TOPICS. WHAT WILL I LOOK TO THE TURBO HOSE? THE VEHICLE DOES NOT YELL. ESPECIALLY LOVE ON RAMPS.
08.05.2020 19:16 # 6
talip206
If you have not had any maintenance done recently, first make a general maintenance spark plug air filter, etc. if the problem is not resolved, you will see other options
08.05.2020 19:16 # 7
Erol Yilmaz
OIL CHANGE FILTERS HAVE CHANGED A MONTH BEFORE.
08.05.2020 19:16 # 8
talip206
When did the spark plugs change?
08.05.2020 19:16 # 9
Erol Yilmaz
I haven't changed it since i bought it. DO YOU HAVE A PROBLEM SPARK PLUG? OR A FAULT FROM TURBO?
08.05.2020 19:16 # 10
my friends said a lot of things, teacher, but first, change your spark plugs.
sonerkyl 2015-05-15 16:25:14
08.05.2020 19:16 # 11
xmen
Did you replace the diesel filter while performing maintenance ...
08.05.2020 19:16 # 12
talip206
Hodja, the vehicle has been with you for 3 years and the spark plugs have already passed. If the problem is not with the spark plug, you will not lose it. Start first, it's already over. If not, you can look at other alternatives
08.05.2020 19:16 # 13
Erol Yilmaz
THANK YOU FOR YOUR FRIENDS SUGGESTIONS. NOW I COME FROM INDUSTRY. TURBO FINISHED. NEED TO CHANGE. THERE ARE THE PRINTING ON THE FINISH. IT WILL TAKE A LOT OF EXPENSE. USTA REMOVED PRICE BETWEEN 2000-2250
08.05.2020 19:16 # 14
blntctn
Say the pain of 3 years :)
08.05.2020 19:16 # 15
Erol Yilmaz
YEAH. UNFORTUNATELY
08.05.2020 19:16 # 16
palet
The vehicle is diesel. Could this have something to do with spark plugs? There is no spark plug in the diesel vehicle.
08.05.2020 19:16 # 17
madblueblacksea
[QUOTE = palette] Vehicle diesel. Could this have something to do with spark plugs? There is no spark plug in the diesel vehicle. [/ QUOTE]
As for the end of the subject to comment, I saw you Smile There is no ignition spark plug in the diesel, there is a glow plug in the room. So it has nothing to do with spark plugs.
Printing pad 260
Turbo 800 (KKK brand origin industry) has zero equivalent to 500 TL
300 + 100 400 also says workmanship 1450. You can make the turbo in revision to 250-400 if you save
I think a little more research. The master who made such a difference in price is likely to incur unnecessary costs.
madblueblackse to 2015-05-15 21:55:12
08.05.2020 19:16 # 18
palet
For Pejos, there is an XN branded Turbo which is produced / assembled in Izmir. You don't have to pay a lot of money to the original. 800 to 1,000 TL at different vendors. There is a sale price between. This works without problems in Turbo Pejo and Citroen. In any case, in case of a malfunction, they do not have any problem with the replacement of the product.
08.05.2020 19:16 # 19
Erol Yilmaz
YES . YOU ARE RIGHT. THIS PRICE WAS THE FIRST PLACE I WERE. I DID SOME RESEARCH. THE ORIGIN TURBO - PRINTING BALATA + WORKING IS COST 1500 E AS YOU SAY. THE FIRST MASTER HAS ONLY PRICEED 750 TL INCLUDING CRAFTING. THE PRICE HAS COME TO ME HIGH.
08.05.2020 19:16 # 20
madblueblacksea
I think looking at the first turbo, a master who understands the turbo. Not for those who say, but get a turbocharger. He had a friend on the line, even the original quit made 40 thousand and it was removed as a result of misdiagnosis. The plug-and-play work of the turbo is between 100-150, but you will find it comfortable for 100. Then I suggest you look at the pressure pad. I think the car is loaded with a half clutch throttle to make it pile up, and if you can do that, I don't think there is a problem with the throttle.
Page : / 2
