vehicle bottom drain plugs
08.05.2020 18:54 # 1
netweb
Is it possible for the vehicle to get water inside the drain plugs under the mop of the left passenger and driver section of the 307, I say that I will siliconize and paste those two plugs, only the places that come to the stopper part are wet.
08.05.2020 18:54 # 2
okaNStarss
[QUOTE = netweb] 307's left passenger and driver section of the drain plugs under the mat is possible to get water inside the car, friends I say that I will siliconize and paste the two plugs.
you live in englanded :) there is no left passenger part tr there is a left driver right passenger there is a possibility of getting water from the stoppers If you remove it and clean it with silicone, it will not be a problem if you need it, you will take it back :)
08.05.2020 18:54 # 3
106fb
I have the same problem. I saw the wetness in the sponge under the mop. The engine water does not diminish.
08.05.2020 18:54 # 4
swing67
I have the same problem, because there is no engine water change or loss. Not the top of the spas but the bottom is wet. Especially under the floor, there is wetness towards the pedal side.
08.05.2020 18:54 # 5
Canberk35
There is a leakage in 90% heating radiator or heating pipes. I guess one of the seals is leaking out. Thumbs Up
08.05.2020 18:54 # 6
106fb
I guess you wrote without reading the above explanations. There is no clean water antifreeze, so it is definitely not from the radiator.
08.05.2020 18:54 # 7
swing67
Yes, there is no engine water ...
08.05.2020 18:54 # 8
Canberk35
10 or so titles were opened in the forum, all of them had radiators, as the mat was dry and the bottom was wet. It is unlikely to come from any other place. Especially if the water is in the driver's part ... Canberk35 2015-04-06 23:42:22
