Vehicle at 168,000 KM
08.05.2020 16:09 # 1
cnrars
friends, what maintenance is required for a vehicle at 168,000 km (excluding filters, oil, water, disc lining), and how much does it cost, and a 206 per km?
08.05.2020 16:09 # 2
diesel gasoline?
08.05.2020 16:09 # 3
cnrars
The vehicle is diesel.
08.05.2020 16:09 # 4
I think a diesel vehicle should not be bought at such a high km. Even if the price is affordable, the costs to be opened in the future should be considered.
08.05.2020 16:09 # 5
mimitt
tools from a to z better passed, without a detailed examination, diesel is the engine and in Turkey can be worn motor due to the irresponsible use, a healthy motu if and maintenance made complete the diesel pump, Tirgu is, so I think the vaccine to bilir. engines, including turbo important in the body.
08.05.2020 16:09 # 6
cnrars
How long does the turbo wear under normal conditions? And the diesel pump isn't too expensive, I think?
08.05.2020 16:09 # 7
cnrars
[QUOTE = cnrars] How long does the turbo wear under normal conditions? And the diesel pump is not too expensive, I think? [/ QUOTE]
no no diesel pump & nbsp; it was expensive & nbsp;:) & nbsp;
08.05.2020 16:09 # 8
Before I Start My Message I Would Like To Remind You Like Caner Bey Brother ...
Age Information of Your Location You Didn't Share Anything ... Let Us Help Us Healthier ...
If there is no problem in the vehicle, I think it can be bought ...
There Is Nothing More Than Kilometers ...
If the Vehicle Is Over 500 Thousand ... Then Do Not Hesitate To Buy You Can ...
To Give an Example,
Haşim Ayaz, We Are The Managers Of Our Site, We Have At least 250 Thousand Of The Vehicle Currently, There Is No One Sound Problem In The Engine ... The Man Who Didn't Do Anything Other Than Routine Maintenance ...
Sapa Sağlam;
Me In 2008 ... 2004 Model 132 Thousand Gasoline 307 I bought ... 21 days after I got the engine embraced ...
When I say Repairman Falan Fistan ... I bought a completely new engine ... Total 6.OOO Liram Gone Status Solved
Whereas it was 132 thousand;
Previous Owner That Vehicle Human G Make sure if ibi was used, we wouldn't have experienced any trouble in that vehicle ... Or you wouldn't live ... If you say more than 60 - 70 thousand ...
If there is a kilometer obsession in the person who will buy a car; I Do Not Recommend Buying A 2nd Hand ...
Buying A Zero Vehicle Will Make More Reasonable ...
I Give Many Examples & nbsp; "Laugh" I am Aware, But There Is Something You Need To Know ...
2010 Model 55 3 Pieces Painted DIESEL (Stock) 206 or 25.OOO TL If You Want ... In This Case To The Seller & nbsp; You Guess What To Do ... "Blink"
< editID> AlbaYDemircaN 2011-09-24 14:02:34
08.05.2020 16:09 # 9
xMEGANx
1. + As high as km, vehicle provides higher performance compared to km low vehicle. It should not be forgotten. If you read there was a 508 example. If the maintenance is in good condition, the engine is intact, this km high event is already in our country.
08.05.2020 16:09 # 10
mimitt
We can examine the turbos in two ways, the ones that can be revised and the ones that need to be renewed are not possible to say a clear figure for a turbo revision, but with an average of 500 to 600 workmanship, a new turbo can start from 800 to 3000 TL according to the brand, and the turbo will change the devil. I've had this in the volvo s40 t4, it looks like this, now the entry of this is the same as mine but this is bigger?
- master this fits my car?
> - what about the pressure?
- can stay up to the level of this rising up to x bar?
- how much is this brother xxx xxx & nbsp; bi & nbsp; let me tell you, dad or my car turbo ... i have so many things at the beginning of the month ....
- (father) my stomach is full son, tell your mom ...
from mom support is received ..
- ok master this is it. when will we take the car out. put it in the trunk in the turbo, i will tear it apart:) & nbsp; s40 t40 is 240 hp instead of 200 with other extras :)
mimitt 2011-09-24 14:42:50
