Vee belt
08.05.2020 21:20 # 1
kaan206
206 3k 1.6 8v I want to change the v-belt of my vehicle and the bearings attached to this belt.
sometimes sound sounds. Which bearings can I replace?
tensioner bearing?
alternator bearing?
What are all the bearings connected to this vehicle?
I would be happy if you help
kaan206 2019-10-16 21:23:06
08.05.2020 21:20 # 2
you don't need to change it all bro, it usually comes from the tensioner bearing. you can also find it as a set. You will probably need to replace the tensioner roller and v-belt.
08.05.2020 21:20 # 3
kaan206
thank you but i am thinking of changing the sleeve on the charger and going over the garage
08.05.2020 21:20 # 4
it will be the best teacher Thumbs Up
08.05.2020 21:20 # 5
kaan206
[QUOTE = sonerkyl] will be the best teacher Thumbs Up [/ QUOTE]
I exaggerated the job a bit and the belt plus 2 bearings plus timing set and engine lugs and engine mounts changed. Bi crankcase protection hair applied
kaan206 2019-12-29 16:46:31
08.05.2020 21:20 # 6
Mtiryaki38
Today I also left my car to the master, I have 206, 2006 model 1.4 HDi at 220k km
There was a noise from the bearings, how many TL did you give, like howling?
08.05.2020 21:20 # 7
kaan206
[QUOTE = Mtiryaki38] I left my car today too, I have the master 206, 2006 model 1.4 HDi at 220k km
There was a noise from the bearings, how many TL did you sound like hum, hojam bearings? [/ QUOTE]
A master who knows his job is very easy to change the bearing and the belt.
Bn net als original bearing was 68 tl on belt and 60 tl on belt
If the bearing is inna brand, it is original.
kaan206 2019-12-31 11:17:38
08.05.2020 21:20 # 8
omerb
You renewed the car. Halal :))
08.05.2020 21:20 # 9
kaan206
[QUOTE = omerb] You renewed the car that ran. Halal:)) [/ QUOTE]
Well, you're telling the truth, I'm meticulous about the car, if I hear a little sound, I'll sleep, I'll sleep
I got 20 thousand, I paid 15 thousand, I need to do another 10 thousand 😀 kaan206 2019-12-31 21:18:23
08.05.2020 21:20 # 10
zaferr
[QUOTE = kaan206] [QUOTE = sonerkyl] would be the best teacher Thumbs Up [/ QUOTE]
Sir, what are the costs of engine lugs and engine mounts?
