Various sounds from 307 clutch
08.05.2020 19:07 # 1
mcemin
My vehicle is 307 1.4 xr 16v 90hp. When I started and started the other day the first time, there was a fine chirping sound like a belt. This sound continued for a while. Then, when I pressed the clutch, the sound was cut off and he never whirled while he was on the road. But a friction sound started coming from the engine, which I had never heard of before. When I pressed the clutch at idle, I felt that the friction-like sound increased further. I did not hear the crowing that I mentioned at first, but sounds like rubbing continue. Also, I feel a very slight continuous vibration when I press the clutch from the clutch pedal.
I explained in detail. Experienced friends can tell the exact diagnosis and the approximate cost?
08.05.2020 19:07 # 2
mcemin
By the way, there is no problem in grip. I tried in 5th Gear and Miscellaneous gears. The engine clears and stops completely.
08.05.2020 19:07 # 3
palarec
Like the clutch ball, it was summer in me, on the way to vacation. I stayed on the road.
08.05.2020 19:07 # 4
mcemin
Many people say that there is no harm but the sounds that come are bothered. Most of those who say a thousand like this until the change of press brake.
How was the problem with your vehicle that you were stuck on?
[QUOTE = palarec] Like the clutch ball, it was summer in me, on the way to the vacation. I was on the road. I think I would look at a master.
MCE's 2015-03-01 15:14:55
08.05.2020 19:07 # 5
palarec
In the same way, there was a sound similar to the belt sound when the clutch pressed. After a short while the clutch press began to increase, the gear shifts became harder. At the last take-off, I made a tremendous tremor and distributed the ball.
08.05.2020 19:07 # 6
mcemin
[QUOTE = palarec] sounded similarly to the sound of the belt, when the clutch pressed the clutch.After a short time, the clutch began to increase, the gears shifted, and the last thrust had a tremendous vibration and distributed the ball. [/ QUOTE]
Thank you for the information you provided. I have to follow the service without losing time. How much did it cost you? And have you had it at the authorized service or at the private service?
