Valves Changed and No Sound From Air Filter
08.05.2020 17:33 # 1
tlp
Friends & nbsp; hello
As a result of an unfortunate incident in early April, I had to replace the engine valves (timing belt was broken).
We took care of the engine, we did not have a problem. Thank goodness
I can not get any sound from the air filter kit, which I used to get a very good sound in the past. div>
but now I can't get that sound even after 3000 cycles
why do you think this is? Anybody have an idea
The sound before the engine was built
[TUBE] BBIoKDiRAEI [/ TUBE]
tlp 2013-04-28 15:23:28
08.05.2020 17:33 # 2
tlp
actual
08.05.2020 17:33 # 3
herry
can you put a photo of your kit?
08.05.2020 17:33 # 4
tlp
This is the kit, this picture is taken before the engine is made (the same after it is done)
08.05.2020 17:33 # 5
tlp
Does the air filter get wet this way?
It was rainy while the engine was being built, I wonder if it got wet outside
08.05.2020 17:33 # 6
fexzi
throat shortage electronic gas does not fully open the throat probably sounds less than it, connect it to the computer and see the throat throttle open, if I remember it, you should have electronic reaction gas.
08.05.2020 17:33 # 7
mev347
the air filter is getting very hot there. I used it for a week.
08.05.2020 17:33 # 8
tlp
[QUOTE = fexzi] throat shortage electronic gas does not fully open the throat probably sound less than it, connect it to the computer and see the throat throttle open, if I remember it wrong, you should have an electronic reaction gas. [/ QUOTE]
Yes, the throat butterfly opens with the command of the brain. >
08.05.2020 17:33 # 9
fexzi
It was the game that came to my mind at the first stage, but the other alternative is that the adjustment of the sentence when the timing belt is installed is not done properly compared to the previous one.
08.05.2020 17:33 # 10
tlp
Peugeot player said to a friend sent
I left the car where I had the engine built today
The guys said it wasn't a sentence, they said we didn't have a tactical apprentice. there is no problem
What kind of setting is there in the syntheses?
08.05.2020 17:33 # 11
fexzi
When installing the timing set, the skilled craftsman knows directly, which point is standard in which vehicle, there are holes in the pulleys for adjustment of the 307, there is a similar knot point in the lower tensioner pulley.
08.05.2020 17:33 # 12
tlp
In fact it looks like a problem in shooting and working
Take a look at the adaptation of the butterfly throat
If he doesn't show anything to him, I'll show him another master.
08.05.2020 17:33 # 13
herry
I think it's not a problem with the filter, but I recommend you to change the filter pipe a little more and translate it towards the battery a little more, the radiator gives very hot
08.05.2020 17:33 # 14
tlp
The current stance is different
When the water event is done I will lower the left fog lamp there
Summer is here or it won't be healthy like this
