valve sign in the display |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 18:11 | # 1 |
Adem Kurtuldu |
| 08.05.2020 18:11 | # 2 |
kursat3006 |
That is the malfunction lamp. If they couldn't put it together, take it and take a look
| 08.05.2020 18:11 | # 3 |
Adem Kurtuldu |
Okay brother, will she make a problem soon?
| 08.05.2020 18:11 | # 4 |
kursat3006 |
Now all sorts of troubles will also be on that lamp. So maybe it is small, maybe it is big, it is not clear that it is not clear, so take it to your master.
| 08.05.2020 18:11 | # 5 |
Adem Kurtuldu |
Okay, thank you. No need for excitement.
| 08.05.2020 18:11 | # 6 |
Motor Malfunction Lamp is connected to a computer, it doesn't go away, it goes out when you make km. If you don't have a problem, let's look at it. |
| 08.05.2020 18:11 | # 7 |
ERDINC |
After some maintenance, the malfunction lights are on because the sensor does not detect the brain when the sockets are removed and inserted, but after 2 - 3 km, it goes out.
| 08.05.2020 18:11 | # 8 |
Adem Kurtuldu |
Then, some time is late, we will not take it.
| 08.05.2020 18:11 | # 9 |
Adem Kurtuldu |
There will also be a slightly different topic, but is the fog lamp in the back lit by the parks?
| 08.05.2020 18:11 | # 10 |
[QUOTE = a.kurt] There will also be a slightly different topic, but is the fog lamp on the back lit by parks? [/ QUOTE] In its original, no, it does not burn, only with short and long lights, with parks, the back fog does not burn ... |
| 08.05.2020 18:11 | # 11 |
Adem Kurtuldu |
As you said thank you all, the lamp turned off spontaneously in the morning
