valve settings
08.05.2020 14:02 # 1
asil 206
my friends car 2006 model 206 xdesing 1.4 gasoline 8v, it sounds like two clicks to the vehicle idle sometimes, it seems to me like a valve but some friends said that my car has an automatic valve and no valve adjustment would be glad if you could help ConfusedConfusedConfused
08.05.2020 14:02 # 2
hasimayaz
What is the valve adjustment in the 2066 model car? There is a valve adjustment, but not every master can do it .. I think the sound comes from somewhere else. Listen to the side of the belt carefully.
08.05.2020 14:02 # 3
asil 206
master sound does not always come, it stops after 10 seconds when you stop pressing the gas.
08.05.2020 14:02 # 4
hasimayaz
[QUOTE = noble 206] master voice does not always come out, it stops after 10 seconds after the gas stops by pressing [/ QUOTE]
First, let's check the steering fluid. Let's try how the air conditioner on or off affects the situation. Does it cut the sound when you press the clutch pedal ??
08.05.2020 14:02 # 5
meandros
I think I talked to you about the sound problem ..
olyor hasim too brother said egr but i don't know omu
