valve setting
08.05.2020 16:15 # 1
enes119
Although my
vehicle is gasoline, it works like a diesel, master. Where can I make the valve setting in Ankara? and how it is an event Reviews
08.05.2020 16:15 # 2
berk2309
If there is a good motor master you know, you will go and make him do it because I do not know because I make abc pejoya :) friends who know everything will help :)
08.05.2020 16:15 # 3
enes119
How much does abc cost? is on the way to istanbul? :)
08.05.2020 16:15 # 4
sedataksu
My friend, you posted two different topics for the same question. Wouldn't it be better if you changed the topic?
08.05.2020 16:15 # 5
enes119
I thought it was a different infrastructure so I opened it already. and still haven't got the answer :(
08.05.2020 16:15 # 6
An operation like this:
[TUBE] 89o5rLpbCgI [/ TUBE]
08.05.2020 16:15 # 7
enes119
koliva bro thank you very much.
08.05.2020 16:15 # 8
they said you would leave the car in the evening & nbsp;
did it take so long?
maverick 2011-10-16 22:21:12
08.05.2020 16:15 # 9
enes119
Not long, brother, this event is done when the engine is cold ... it is also done when it is hot.
08.05.2020 16:15 # 10
zavur
Get the vehicle somewhere you trust because you leave the car there, or the apprentices can stop around the car "Grin"
08.05.2020 16:15 # 11
sedatdatse
I will ask separately bey
what are the normal size of the pejos?
are the different sizes of the sillage between the intake and exhaust valves.
if anyone knows help
& nbsp;
08.05.2020 16:15 # 12
enes119
what is your brothers . is a gauge valve valve or piston ring mouth spacing etc ... of course it is different suction is bigger in atmospheric engines such as because the air gets inside in vacuum, the larger the diameter, the more oxygen is taken, but the exhaust is not so important. burnt air and gases will go with pressure, no problem :)
08.05.2020 16:15 # 13
enes119
my letters accidentally passed by themselves
08.05.2020 16:15 # 14
sedatdatse
I know what brothers are and what you do, you didn't understand what I wrote there
we are talking about valve setting
& nbsp;
one
valve settings between exhaust and suction valves different on some vehicles between
such as 0.35 inch or 0.25
you understand
08.05.2020 16:15 # 15
enes119
When I say something else, my brother has gone elsewhere, so sorry. The difference between the two is absolutely different.
