V-Belt displaced - tension ball broken |
| 08.05.2020 20:41 | # 1 |
OguzhanKucuk61 |
At first he did not bother me, but he said he had no function. It has nothing to do with places like hydraulics, recirculation, and batteries. He said he just turned the strap. He assured that he wouldn't have a problem if he wore a short strap. In the event of a problem, I said to my surety. So I said do it. I said save me at least cost. The vehicle now lies in the shop. Tomorrow morning, my first job will take care of my vehicle. Is diagnosis and intervention correct? Does the system work properly with a short belt without installing the tensioner ball? Does it give me trouble? Thank you very much for your help. |
| 08.05.2020 20:41 | # 2 |
sonerkyl |
Oğuzhan be well, brother first. I don't understand why the tensioner ball was so hard to put on, so there is nothing difficult to do. There is a tensioner ball slab. If the piece is not so expensive, 150 TL in total and 50 TL in labor, let's say 200 hdai has not been max 250 TL. |
| 08.05.2020 20:41 | # 3 |
Would it be the tool makers if it didn't work? I think whatever is required should be done, it should not be easy.
| 08.05.2020 20:41 | # 4 |
It is enough to lift the tool on the fiber to remove the tension ball. As far as I know it has 3 screws. unscrew it, put on the new belt, put back the complete new of the tensioner ball, and you're done. Maximum half an hour of work. How many how many can you escape from that master? Also, thanks to the tension ball, we can easily understand whether there is a problem in the bearing and its pulley. Do not run tightly without tension. Strap 35 tl tensioner 110 tl labor 50 tl 200 TL max. as original parts. |
| 08.05.2020 20:41 | # 5 |
Hello there, The main task of the tension ball is that the belt absorbs the load changes on the belt, such as hot-cold, sudden gassing and gas cutting. Your tensioner ball (will definitely change on the belt) has completed its life and broken to protect other pulleys, bearings. You have to do; Taking the new belt + tensioner bearing and having it repaired as it should with a fee of 150 TL (max). Not giving anything to the master in question other than Allah's salute Get well soon. |
| 08.05.2020 20:41 | # 6 |
OguzhanKucuk61 |
Indeed, if it is such a serious situation, I will go and crash on their heads. Yesterday we laid the car in the shop, they still have not started today. I am not thinking whether I am misrepresenting the piece. He said that Dinamo should be dismantled. He showed me the piece, not clear. The broken part is inward. I don't understand |
| 08.05.2020 20:41 | # 7 |
OguzhanKucuk61 |
I met with the master right now. He said that the foot to which the tension ball was attached was broken. That was the case that I saw.
| 08.05.2020 20:41 | # 8 |
OguzhanKucuk61 |
And it won't be using a short strap. He said he had to disassemble and change.
| 08.05.2020 20:41 | # 9 |
Get well soon..
| 08.05.2020 20:41 | # 10 |
OguzhanKucuk61 |
Thank you brother @ ersin61
