Using the tape handle
08.05.2020 20:50 # 1
GiTaRRa42
Is there a friend who made a connection from the 2006 tape sleeve?
My Sony brand tape.
08.05.2020 20:50 # 2
OguzhanKucuk61
My teacher can do it if the tape is compatible. Check its compatibility. In some tapes, this adjustment can be made from the setup menu. You can make the method of assigning keys. In some, it can be done with additional apparatus.
08.05.2020 20:50 # 3
GokhaN
There are not many models that fit in pioneers @ OguzhanKucuk61
08.05.2020 20:50 # 4
GiTaRRa42
where can i check it arc sony new model tape but where do i look?
08.05.2020 20:50 # 5
GokhaN
Write your model, let me see the features
08.05.2020 20:50 # 6
maximusti
To be done, there must be an entry on the back of the confirmation that says W / R.
It can be done by removing the control on the vehicle and installing resistance on the supported values.
I was able to do it on my own pioneer confirmation.
08.05.2020 20:50 # 7
GiTaRRa42
Write [QUOTE = GökhaN] model and let me see the features [/ QUOTE]
sony cdx-g1100u code these are my friends.
08.05.2020 20:50 # 8
maximusti
[QUOTE = GiTaRRa42] Write the model [QUOTE = GökhaN] let me see the features [/ QUOTE]
When I look on the internet there is W / R input,
the rightmost entrance can be connected with the aux socket there,
The wired controls of the end can be adapted to the original control lever on the vehicle.
08.05.2020 20:50 # 9
GiTaRRa42
I hope there is someone who knows how to do this
08.05.2020 20:50 # 10
OguzhanKucuk61
I didn't want to open an extra topic. I am back to the original because the tape I attached later broke down. It is very pleasant to use steering wheel control, yes, but it is not controlled by radio.
Is there a tape recommendation for the controller? Or a tape with a setting menu, assigned to the Control keys, without the need to cut and mow extra?
08.05.2020 20:50 # 11
onlycihan
We have a friend who understands this job from electronics that solves it with his own ability and skill. Everyone talks about how this work can be done with a simple two resistors, but I don't know what, where or how. My previous vehicle was linea, I even made a speed stabilizer to my car from the sharing of friends who made it there and it was much more complicated than ours, just like attaching the arm and turning it on from the pc. In summary, I believe that this process is actually as easy as making an aux. Let's solve the cotton hands like pocket and this steering control business together.
08.05.2020 20:50 # 12
GiTaRRa42
There is an absolute solution for the subject, I hope we are waiting for your friends.
08.05.2020 20:50 # 13
maximusti
If I can pull my head together, I will try to make a diagram next week. taking precedents for what I did on my own vehicle.
08.05.2020 20:50 # 14
Alico28282828
My master also has sony dsx-a2000ui, blue input is available, but w / r does not write audıo out or something, if i buy an apparatus
08.05.2020 20:50 # 15
onlycihan
[QUOTE = maximusti] If I can pull my head together I will try to make a diagram next week. taking precedents for what I did on my own vehicle. [/ QUOTE]
bro you have collected your head, hopefully let's take this scheme :)
