Using the Fender Signal as a Park and Signal |
| • Homepage » PEUGEOT MODIFIED PLATFORM » 206 | |
| 08.05.2020 16:39 | # 1 |
tlp |
& nbsp; I'm not sure that the subject has been opened before, I searched but did not find it. If it has already opened, sorry in advance. & nbsp; I made the process of connecting the signals to the parks (semi-american park) maybe I wanted to write it here as it would be useful. & nbsp; Actually, the event is very simple, the only job is the minus pole (chassis) of the cables leading to the fender signal. fixing and pulling cables from the parks to the fender is all that. & nbsp; After detecting the negative pole cable, I cut the cable from the appropriate location. Then the fender from the plus pole of the parks I pulled a cable to the signal (I tried a little because I did the process when it gets dark, but I did it when I pulled the cable, but I finally did it) The last situation was the plus pole coming from the parks at one end of the fender signal. DIV > & nbsp; Parks are open While the fender signal acts as a park, it acts as a signal when the signal is on, but the signals are reversed relative to the front and rear signal (one ends while it is on) & nbsp; A costless, effortless and repairless operation I guess it would be a problem during the inspection, so it would be useful to set it to reconnect the cable that you cut because of it. & nbsp; DIV>
| 08.05.2020 16:39 | # 2 |
safrane23 |
Health to your hand has been good in dreaming. Nothing is as nice as standing in front of your own labor and watching it. Thank you for enlightening us too.
| 08.05.2020 16:39 | # 3 |
AydinBeyol |
thanks for sharing.
| 08.05.2020 16:39 | # 4 |
I did the same, yes, cross, but it looks nice int. they sell a circuit to prevent this cross burn
| 08.05.2020 16:39 | # 5 |
I put on a red led, it turns on solid red.) & nbsp;
