Using 55 cheeks on 17 rims
08.05.2020 19:10 # 1
tezmert
There are 17 wheels on my vehicle and 205x40x17 tires on it.
I went to the tire today and said 205x55x17, but it seemed to me that 55 cheeks will rub against the fender.
Were you using 55 cheeks on 17 rims?
teşekürler
08.05.2020 19:10 # 2
riderzist
[QUOTE = tezmert] I have 17 wheels on my car, 205x40x17 tires on it, as I know, on the roads of Istanbul, the flour hits a small rim.
teşekürler
I was using 205 50 17 at 307 and I think even 207 would be big. You should do the same with the original dimensions of the vehicle.
you can look without rim tire calculation.
08.05.2020 19:10 # 3
Canberk35
Thank you [/ QUOTE]
Even the tires you use are not correct, hodja. If I'm not mistaken, the standard tire length for 207 is 185/65 / R15. With the tire you are using now, all the information regarding the mileage of the vehicle proceeds incorrectly. If the standard tire lengths I have said are correct, the most compatible tire for the 17 "rim is 45 sidewalls at 205 bases. The deviation will be much less with this selection.
On the other hand, 55 cheeks with 17 rims will probably be a bit too big for 207 hoods. I think that most likely there will be friction in the cistern and under load.
Canberk35 2015-03-20 01:23:37
