Useful Features of Peugeot 308 ..
08.05.2020 14:08 # 1
taylan43
Hello friends;
I wanted to share with you a few features for Peugeot 308 from other forums and I think it would be very useful for 308 owners:
For Comfort vehicles;
- If there is no follow me home, after turning off the vehicle's ignition, it will be activated if you pull the headlight lever to yourself like a selector. After a certain time, the headlight turns itself off.
- After closing the vehicle's ignition, all the automatic windows buttons are working within 30 seconds or 1 minute.
- After turning off the ignition of the vehicle, you got off the vehicle within 30 seconds or 1 minute. You see that the windows are open.
- If you turn the wiper switch on one level within 30 seconds or 1 minute after turning off the ignition of the vehicle, the wipers stay in the middle of the window, it works very well in winter.
- If you want to throw the wiper water while the vehicle is in motion, it is enough to pull the wiper button to yourself, it throws the water itself for a certain time. You don't need to pull the lever on yourself.
- Since the air conditioning system of our vehicles does not contain chlorine, it is not harmful to the ozone layer. It is a very environmentally friendly vehicle.
- Friends who use automatic diesel 308, when your vehicle is in full automatic mode, you can make the gear up and down with the gearshift paddles on the back of the steering wheel while braking or braking. You do not need to switch the vehicle to manual mode, which is a great feature.
- Automatically works on rear wipers if you shift into reverse in rainy weather
- If you press the volume up and volume up buttons of the Sound system joystick under the steering wheel at the same time. The voice "mute" comes into silent mode.
- When you operate the wiper, the first mode is the mode sensitive to vehicle speed, which says "I". As the vehicle accelerates, it automatically accelerates on the wipers.
- You can always keep the daytime running light feature on your trip computer. A nice feature is on my open road in my windshield .. Sırıtma
If you share the information that I have forgotten to add or have been missing, I would appreciate it.
08.05.2020 14:08 # 2
let me add one
If you put it back and adjust the mirrors, it will stay in memory and it will show the place you like.
Forward it switches to normal mirror position
08.05.2020 14:08 # 3
sbereket
How can you remember the location of the mirrors when you go back, can you explain the trouble in detail.
08.05.2020 14:08 # 4
I could not run it too, it writes in the booklet.
Also I couldn't run the follow me feature.
08.05.2020 14:08 # 5
hasimayaz
Some features are available in all vehicles of 2004 and above. I listed below
- After closing the vehicle's ignition, all the automatic windows buttons are working within 30 seconds or 1 minute. (This is also different in 206, if you do not remove the contact after the engine, the window controls stay on, cancel when the key is removed)
- If you turn the wiper switch on one level within 30 seconds or 1 minute after turning off the ignition of the vehicle, the wipers stay in the middle of the window, it works very well in winter. (this tool is a feature for washing, but of course it is used as desired)
- If you want to throw the wiper water while the vehicle is in motion, it is enough to pull the wiper button to yourself, it throws the water itself for a certain time. You don't need to pull the lever on yourself. (I don't know how long it takes in 308 but 206 is just a few seconds)
- Since the air conditioning system of our vehicles does not contain chlorine, it is not harmful to the ozone layer. It is a very environmentally friendly vehicle. (R22 gas has been banned in all air conditioning systems since 2008, I may be wrong in 2008, may be in 2007)
- It works automatically on the rear wipers if you shift into reverse gear in rainy weather (valid if your front wipers are operating at 206)
- When you operate the wiper, the first mode is the mode sensitive to vehicle speed, which says "I". As the vehicle accelerates, it automatically accelerates on the wipers. (As you accelerate in standby mode at 206, replay time increases)
hasimayaz 2010-07-18 21:17:13
08.05.2020 14:08 # 6
sbereket
I would like to add to the features. In very rainy weather, rain water can flow into the door between the windows. It may make you wonder for days and then think of coming from the gas tank. Coincidentally, when you open your back door, what can you say when you hear the sound of water again. Don't worry, the car can also be used as a water tank. I removed at least 3 liters of water when I opened the gasket a little under the door Confused .
Greetings to your knowledge ...
08.05.2020 14:08 # 7
Embarrassed
08.05.2020 14:08 # 8
ali oncu
how much has it got dear Embarrassed
08.05.2020 14:08 # 9
oguzhan29
nice Alkış
08.05.2020 14:08 # 10
husmen73
[QUOTE = webbee] let me add one to one
[/ QUOTE] I don't understand what the mirrors are going to be going back at all. Does it allow the mirrors to move down a little (as we adjust) without ever playing the sidewalk from the sofa?
08.05.2020 14:08 # 11
beautifully
08.05.2020 14:08 # 12
I am not using 308, but let me try to help, it was in my previous car.
If this does not happen, the button that you have turned, my 206 is also turned to the right and to the left, if you have this feature, it must be turning back down.
08.05.2020 14:08 # 13
Haksen016
thanks for the useful information.
08.05.2020 14:08 # 14
bayelektronik
most of these features are also available in 307. Really nice features
08.05.2020 14:08 # 15
Haksen016
Yes, 308 in 307 does not have much superiority in terms of hardware, of course, friends who use a new vehicle and a very nice vehicle should be used by you and without any problems.
08.05.2020 14:08 # 16
m.peker
thanks for informations
08.05.2020 14:08 # 17
muratgulen07
Is this memory mirror available in 2006 comfort 307?
08.05.2020 14:08 # 18
xMEGANx
Almost all of the features are available in 307 =) As far as I know, there is no single mirror. I would be glad if you tell us how to put it into use, I have 2007 307 Comfort package
08.05.2020 14:08 # 19
mimitt
I have stayed at these memory mirror event Ayyuka te, this feature has only premium car does not work in their at all, the owner's manual prepared by the full equipment package, which Turkey is told even features not included in the product range. mimitt 2011-04-28 01:36:33
08.05.2020 14:08 # 20
ADM
Is there a 307 memory for those reverse gear mirrors ..
Page : / 2
