use tire sidewall diameter differently
08.05.2020 17:39 # 1
Aziz
hi guys.
I'll buy a new tire, and as an idea,
prevents it from being present again as 195 / 50 / 15 will be back 195 / 55 / 15
can you give us an idea of what can be positive or negative? div>
Reviews
Note; some super vehicles: D & nbsp; the rear tires are big, they are small, I was inspired by the middle of course, but they are generally rear-wheel drive vehicles :)
08.05.2020 17:39 # 2
rolandgarros
Well, I have no idea, but I want the four to be the same type as brand / model / pattern "Smile" & nbsp;
08.05.2020 17:39 # 3
umut_25
Master, you know that there is no ESP in our vehicles. I would recommend buying a wide base tire. Okay, it affects the fuel a little bit, but the brakes are shortened and the road is more elegant than the grip. I use 205/55/15. In the next change, I can further increase the base width. Even friends who use it now think that the grip is good according to 206. I think about it ...
08.05.2020 17:39 # 4
Aziz
I am getting up to date, this vehicle does not bother me 195/50/15 even though it is a snow tire.
I don't think differently, I don't change 195 / ** / 15 in width and inches that fit my vehicle
08.05.2020 17:39 # 5
howard
brother is the reason why the rear tire is big and wide base is for road holding and performance (for the rear-wheel drive vehicle) & nbsp; it is preferred in the rear-wheel drive cars. I don't think you are expanding the base because it doesn't change in inches. something unnecessary fuzzy :) But I can see my car is high on the rear-wheel horse :) best use same sizes brother bro you tires howard 2013-06-01 13:10:45
08.05.2020 17:39 # 6
howard
If the wide tire does not exaggerate, I think that if the beautiful engine cannot respond to that wide tire, more than 195 I think both increases the fuel and decreases the speed for unnecessary pejo. because the wider the area touching the ground, the higher the friction. As we all know, the more the friction, the slower the object :) a minus is affecting the opposite direction in the winter, the wider tire causes the vehicle to get out of control faster .. so everything is more damaged "Smile" medium is good and if you say my car has 300 horsepower then it would be useful to expand it. If the vehicle is being modified, it is best to make changes by thinking about how it affects other parts.
08.05.2020 17:39 # 7
Aziz
I like the writings of howard, these are the answers I am looking for, I want to make me if there will not be a minus or a plus. so it may even be 195/60/15.
by the way, I think I'm going to get a tire for free, I am very excited, I will go soon, there are 2 sets of tires, 2 of them 205/60/15 2 195/50/15 impetus revo + I'll buy it if they give it :)
meanwhile 205/60/15 said to the boss, try it if you want very different images, try this different . I don't know if I don't like free tires after all, I'll sell them.
THERE IS NO DAMAGE DAMAGE
08.05.2020 17:39 # 8
howard
As you said, you have reduced it from 65 to 45 .. The first factor is that it does not matter, the second factor is the quality and weight of the rims, brother, let's go late 195/45/16. you take it from somewhere and give it somewhere. You take it from comfort and give it to the road grip.
NOTE: Width does not matter much in high horsepower vehicles. other than increasing road holding (such as increasing fuel, reducing performance)
howard 2013-06-01 13:37:08
08.05.2020 17:39 # 9
tigerland
[QUOTE = Aziz] I like the articles, howard, these are the answers I am looking for, I would like to make me if there will not be a minus or a plus. so it could even be 195/60/15.
By the way, I think I will get a tire for free, I am very excited, I will go soon, I will buy 2 sets, 2 205/60/15 2 195/50/15 impetus revo + if they give the company a gift tire :)
In the meantime, 205/60/15 said to the boss, "If you want such a different image, try this one." I don't know if I don't like free tires after all.
IF YOU DO NOT DAMAGE
When the organ size at the door is not a writer, the fuel will increase, the traction will decrease, the speed will change, the gti is 195 45 16 dimensions
I used gti, of course, the choice is yours :)
08.05.2020 17:39 # 10
howard
My car has 1.4hdi 195 45 16 with the original pejo rims, despite the fact that the fuel increased performance decreased, there is no difference on the straight road but the curved and the ramps noticed that it accelerates a little later. it happens when I have to downshift if I entered at a low speed.
because if I do not know wrong, the dimensions of hdi are 14 "and thinner sidewall bicycle tire.
08.05.2020 17:39 # 11
Aziz
door information as follows,
Well tell me, I want to make the back big and the small front 195/55/15 front 195/50/15 How about?
08.05.2020 17:39 # 12
howard
My dear brother, if you say I will compromise comfort, make the front tire 195 45 16, you will not feel any difference, your handling will increase, it will not be exaggerated in fuel and performance. but if you do not use air suspension or a suspension that is equivalent to it, the comfort drops very low that the car drops significantly, but it gives you good handling and good braking. For the rear tires, I am completely commented.
NOTE: If you want comfort, you will make the cheek slightly larger. you lighten the wheels, you must use an original rim. the growth should not be 3% more or 3% lower than the original of the vehicle, so that it does not affect performance and fuel.
howard 2013-06-01 14:20:54
08.05.2020 17:39 # 13
tigerland
Yours old model will grow bigger in 195 45 16 in 2001
You know, if you want, grow it as soon as you get it at 205. Do not rub it or try it if it does not. :)
08.05.2020 17:39 # 14
eiknuj
I use 215/45/17 pzero nero tires with 30psi nitrogen, I am very pleased with handling and braking, I recommend. eiknuj 2013-06-01 23:00:54
08.05.2020 17:39 # 15
candanxyz
Exactly Big smile
08.05.2020 17:39 # 16
Aziz
unfortunately, they only give gift tires for linea - albea - clio type vehicles, fabrication dimensions :(
I think the tires they make from the material, or the tires they make with increasing material, produce and give a standard :(
They also want the information of the vehicle they provide, the company title or something: We bought the D 1 team and the 2nd team needs a company vehicle, let me show the company the company vehicle and buy and sell the standard tires.
08.05.2020 17:39 # 17
Alicilik
Saint master,
The vehicle's center of gravity is a crucial point for handling and fuel consumption. If this vehicle is 206 and a gti in Heleki, it is necessary to pay extra attention to them. He is not a tool to defend himself in bends that will stop when he says. I know that there is no ESP. It is not worth risking life for a difference of 100-200 TL and just a look.
For the aerodynamics and performance of the vehicle, be in favor of the values written at the door whenever possible. It is nice to enlarge the inner diameter for the appearance, but I think it would be healthier to change the 4 wheels to the same extent. You will keep the back 5% longer on 195 cheeks than on the front. This shows that with the appropriate tire pressure, the back side will be in the air at most 5% compared to the front, in my opinion, an important rate is not worth taking risks. LOW & SLOW mod, if you say that I get stuck, I wouldn't think it would do much rubbing unless it is bigger than 205.
08.05.2020 17:39 # 18
Aziz
Thank you very much, Ali Hodja, but did you write for 195/55/15?
I think it sounds like you wrote for 205,
my final decision. rear 195/55/15 front 195/50/15
I want to enlarge the back cheek a little. this
"In 195 cheeks, you will keep 5% longer than the front. This shows that with the proper tire pressure, the back side will be in the air at most 5% compared to the front, and it seems to me that an important rate is not worth the risk."
of course, if it creates a risk, I will keep it equal, but I am not looking for a plus. Of course, if the back side is 5% higher in the negative direction, it will create a risk.
08.05.2020 17:39 # 19
Bugra
It doesn't seem right to me that these cheeks are different in size. I don't give you a scientific answer if you say why, but it doesn't sound right. I can say you are a fireplace. It's like wearing shoes of two heights.
08.05.2020 17:39 # 20
howard
saints say you are enlarging the cheeks, but watch out in the bends, it looks like there is a risk of sliding on the back, thin back how it feels as if the speed with a slightly lowered tire, the car throws itself to the left and you can test it and make sure you have a test vehicle and front tires are harder than the rear tires. I said it would probably be soft so the probability of slipping is high. You test it and try it.
Page : / 2
