URGENTLY HELP
08.05.2020 16:59 # 1
yavuzarslan
my friends car 2006 model 1.4 307 & nbsp;
& nbsp; let me explain the problem first, the vehicle is playing in the rev counter when idling after 30 km If he can collect himself, he does not stop, if he can not, he stops, but if the foot is kept pressed for 2-3 seconds or is wasted in turns, the car will stop.
< / span> they said, clean the throttle's throat, managed it for 2 days, I changed it with the original, I did not understand it for 2 months, but when it was attached to the computer, the throttle was there, there was a scart-shaped cable, they told me that there was a mistake, that the cable needs to change completely, it was around 1000 rubles. When you run it, there is definitely a movement in the century and stops.
The gas claw says no playback car may be the first gas, but it cannot find the problem.
name How can I fix this problem that makes my ill sick? Is it the first gas setting or is it from the cable? I would be very happy if you could help, they could not solve the opium and the sea in the weekend.
08.05.2020 16:59 # 2
muratoner
& nbsp; I don't remember the name of my brother, but I know that there is a very nice private service in konya and I heard that they understand it well.
08.05.2020 16:59 # 3
30 40 km. I understand that this problem arises when the engine is hot. So, when the engine stops when it is hot, when you press the star again, does the star start? The main question is, does this problem happen only when you use your vehicle on gasoline?
08.05.2020 16:59 # 4
yavuzarslan
brother can be doing when the engine is hot but when i press the marsa there is no wait right away
KARDES GASES THE SAME PROBLEM IN GASOLINE, MALASEF
THANKS TO INTERESTED FRIENDS
