Urgent information please
08.05.2020 15:54 # 1
Gokhan_S
friends I am a beginner, there are 2nd hand peugeot 2001 model 206.
What is the use of the vehicle at high speed? What is the use at low speed? There is a tachometer next to km.indicator, what is it for? how high circuit passes?
08.05.2020 15:54 # 2
The indicator shows how many revolutions per minute the engine rotates per minute. So, for example, the engine rotates 3000 revolutions per minute when the tachometer is at 3. To use at high speed is to keep the vehicle over 5000 cycles continuously. The shift we call the redline is magnified from the limit of the maximum revolving cycle. (It was limited by the factory at 6250 rpm in 206's.) This provides performance usage but the fuel consumption value is at the maximum level. Ideally, the gear can be increased at 2800-3000 rpm. (For gasoline engine)
08.05.2020 15:54 # 3
Gokhan_S
When I say that the gear is increased at 2800 - 3000 revolutions, for example, I feel that the vehicle is drowned as it gets loaded into the gas after getting up, this happens when I switch from 1-gear to 2, the speed indicator of the vehicle comes to 2000-3000s as it is loaded into the gas after the 2nd gear, you say raise to 4?
08.05.2020 15:54 # 4
Is your vehicle diesel or gasoline?
08.05.2020 15:54 # 5
Gokhan_S
gasoline
08.05.2020 15:54 # 6
Normal is 3000 but it depends on your usage style. The higher you shift, the higher your fuel consumption. But if you throw it in 2000 to make it less light, it will be harmful to use it at a very low speed.
I couldn't understand how to drown when I say drowning. Maybe you may be lifting your foot off the clutch slowly because you are a beginner. Therefore, it cannot be accelerated immediately.
08.05.2020 15:54 # 7
mon
Okay, when you go in 1 gear, when the speed is 3000, put the gear in 2.
As soon as the second gear is 2000, the speed will be around 2000, the speed will be 3, the speed will be around 2000, and the speed will be 2000, the speed will be 2000, the speed will be 2000, the speed will be 3000, the speed will be 2000, the speed will be 2000, and the speed will be 3000.
08.05.2020 15:54 # 8
[QUOTE = mon] okay, when you go in 1 gear, put the gear to 2 when the speed is 3000.
Master what did you do, friend novice.
Parts other than plug to Gökhan R are correct. Gülme
08.05.2020 15:54 # 9
Gokhan_S
When I say drowning, I just slow down the car when I try to pull it from 2nd gear to 1, since the car wants to shift as it presses the gas when it is only at take-off 1 gear, there is a groan in that range, it seems normal, and also there is a lot of stop or slow down in the city sometimes. Why is this not the case?
08.05.2020 15:54 # 10
mon
I wrote so that I know it. Do not get me wrong, do not wear sister R or something.
08.05.2020 15:54 # 11
[QUOTE = Gökhan_S] When I say drowning, I just want to shift the car as I press the throttle on the start, that is, when it is at 1 gear, and it is a normal moan in that range, and also trying to pull the car from 2nd gear to 1 because it is a problem to stop or get up very often in the city. I slow it down, sometimes I don't get into gear 1, why is this? [/ QUOTE]
If it does not go from 2 to 1, the vehicle most likely wants the press pad. You'd better show it to a service.
There used to be vehicles with a black gearbox. You couldn't downshift. When I said that it does not go from 2 to 1, it came to my mind. It was in a friend's Vos Vos. Kahkaha
08.05.2020 15:54 # 12
Gokhan_S
What is the service here? I took it to the industry 15 days ago in the makeshift places .... I changed the front left of the car to change the wedge, when I disassembled, I sensed an abnormality, the gearbox oil of the car was empty, I suddenly looked at the oil, I asked why it flowed, do you think it flows?
08.05.2020 15:54 # 13
Gokhan_S
Wall
08.05.2020 15:54 # 14
mon
the job is difficult but if the vehicle does not go from 2 to 1 or if it needs to decrease a lot of speed it is normal all the vehicles are like this, this is not a malfunction.
08.05.2020 15:54 # 15
yes, shrinking from 2 to 1 passes when the speed decreases in many vehicles.
Mon brothers explained it well, of course, at the beginning, you will throw it by looking at the tachometer and then you will get used to it without looking at your voice. Thumbs Up
In the meantime, it would be better if you add the details about the vehicle to the signature of your drinker and write your car details :)
08.05.2020 15:54 # 16
metin
[QUOTE = Gökhan_S] here I took the service to the industry 15 days ago, they had a makeshift place .... when changing the front left shock absorber of the vehicle, I sensed an abnormality when disassembling it. do you think? [/ QUOTE]
If there is a share of the vehicle's information in the signature of the province and district.e information in the profile, let friends help you.
08.05.2020 15:54 # 17
+ 999 Thumbs Up
