urgent help please
08.05.2020 15:39 # 1
ozkan206xs
hello friends today i became a new member to this page firstly hello everyone.peugeot 206 xs 1999 1.6 i have a gasoline car engine does not burn oil like staples etc. but we can not find a problem.I would be glad if the knowledgeable friends helped it. When I go at low speed, that is, between 2 -3 thousand cycles, at a constant speed, suddenly the gas is extinguished as soon as it runs out and it does not work immediately after the starter pressure, it waits for about 10 - 15 seconds. I wonder if it is a gas filter.I do not think that the bid is cold or hot without pressing the gas in one starter.
08.05.2020 15:39 # 2
Welcome ... But according to the forum rules, you have to introduce yourself first.
Our members who have completed their new membership and entered the forum, please introduce yourself by opening a new topic under the heading "Let's Know Our Members ". Filling in all the information will help us to know you better.
1.- Your name and surname:
2.- Your age:
3.- Your vehicle (Brand, model):
4.- Your hobbies:
5.- Your profession:
6.- Where did you hear the site:
7.- Your Blood Group:
8.- Your horoscope:
9.- The team you support:
10.- Which county or province are you in:
11.- Your MSN address:
Thank you for your attention.
Peugeot Turkey Fun Club Management
Www.peugeotturkey.co & www.peugeotturkiye.co I
08.05.2020 15:39 # 3
ozkan206xs
I introduced myself Gülme
08.05.2020 15:39 # 4
then welcome to us .. wish you a pleasant and active forum ..
08.05.2020 15:39 # 5
ozkan206xs
can you read my message and help?
08.05.2020 15:39 # 6
[QUOTE = özkan206xs] I like it. Can you read my message and help? [/ QUOTE]
A lot of our friends will help you on the site .. do not worry .. follow the topic ..
08.05.2020 15:39 # 7
extremex16
I think it stems from the fuel system, your narratives point to it. I say start by changing the gas filter.
08.05.2020 15:39 # 8
ozkan206xs
thank you very much. let me replace the gas filter for home ..
08.05.2020 15:39 # 9
[QUOTE = özkan206xs] hello guys today i became a new member of this page firstly hello everyone. Approximately 5 minutes after working, when it goes to low speed, that is, between 2 -3 thousand cycles, it suddenly turns off as if gasoline is exhausted, and immediately after it starts working for 10 to 15 seconds, it does not work at high speeds. I wonder if it is a gas pump or a gas filter. I don't think the bid is cold or hot without running the gas in a single starter. Some of them are sibops, I don't think they said it. I think it doesn't draw me. I would be glad if you help me.
There is a possibility of having a gas pump. Even her role may be impaired.
Do you have a carburator in your vehicle?
08.05.2020 15:39 # 10
ozkan206xs
1999 model 16. 8v 206 xs gasoline so some with injection, half injection, I don't understand much Shocked
08.05.2020 15:39 # 11
ozkan206xs
yes i guess that is bulcaz.or also there is no air filter in the car, 99 models of it consists of two separate boxes, i.e. there is a pipe and a box coming out of the injectors, then there is a big box and there is a filter inside it, there is no second box and i am throwing gasoline amazing fuel 70 km to 40 Does tl gasoline fuel filtering so much difference, do I have another malfunction?
08.05.2020 15:39 # 12
extremex16
There are no parts that will cause headaches as much as there is no air filter in the vehicle. Fuel consumption increases, fuel particles going to the cylinders are mixed with dust particles and whatever you want. The cylinders are drawn against these foreign substances. scenario goes bad. Put on the filter. It would be good if you look at the refill of the gas filter.
08.05.2020 15:39 # 13
d3n1s
There is always an air filter, an open air filter may be installed. As for your problem, a problem to be found by trying, as friends say, seems that the gas pump is not sending enough gasoline, your gas filter may be clogged, the pressure sensor of your gas pump may be broken, the engine of your gas pump may be broken. Start by measuring the pressure of your gas pump, I think, if the pressure is low, we will comment accordingly, if the pressure is normal, your gasoline filter is probably blocked.
08.05.2020 15:39 # 14
ozkan206xs
thank you very much for your help guys. i will visit tomorrow industry :)
08.05.2020 15:39 # 15
I hope you will handle your work as soon as possible, my friend.
08.05.2020 15:39 # 16
teknikerrr
If it does, it increases the likelihood of relay and similar electronic and electro mechanical parts.
