urgent help please
08.05.2020 19:28 # 1
34gz8579
307 airbag light is on, I could not digest, anyone knowing the method of resetting and resetting the cables under this seat
08.05.2020 19:28 # 2
teacher, there is no such thing as resetting from the armpit.
08.05.2020 19:28 # 3
34gz8579
Now dude resetting two of the wires on the right seat is reset, I made it to the master, but this time I couldn't find the master.
08.05.2020 19:28 # 4
hakanerbas
If the airbag light is on, did you first look at the fault record on the device? is there any trouble in the horn? This problem is generally found in the middle of the headlight and wiper arms under the steering wheel, and there is a part called a drum that passes very thin capillary cables. he does it because there is a break or break in the capillary cables. Generally, change is being made. I do their repairs, I renew the cables inside and it does not differ from scratch. First of all, if you can't look at the device and still solve it, I will help you bro.
