Urgent help please: /
08.05.2020 19:20 # 1
muratsen
Hello, we bought the 2006 model 307 from the gallery a month ago, but there was no problem until yesterday, but yesterday I bought it a few hours after parking the vehicle 20 25 meters later, the warning lights (with stop, abs, exclamation mark) all turned on and started to vibrate. Since the car was at the crossroads, I took the car for 10 meters, even if it was forced, then I turned off the ignition and after the act I proceeded a little later, the same thing happened again. did the thing and neither the hand or km hand does not move 0, why do you think the problem is caused?
08.05.2020 19:20 # 2
cihanusta
Take it to a master without leaving you on the road before your problem is likely an electronic malfunction.
08.05.2020 19:20 # 3
muratsen
Thanks, I took it to the industry today, they said there was a problem with the charging dynamo.
08.05.2020 19:20 # 4
ALLEX
[QUOTE]
Greetings I hope your problem will be resolved. But,
We know that there are some awake people in the industry, which is said to be a charger. When the battery starts to last its lifetime, it becomes non-recharging, which sometimes causes the charger to stay in place and load continuously. I recommend you to have the battery checked as well, because the warning lights and the re-opening of the doors automatically after locking them can also be caused by a weak battery. As the battery starts to die, it tires the charge dynamo more and steals it from its life. I think it wouldn't hurt if you had it checked.
08.05.2020 19:20 # 5
muratsen
Thanks for your reply, after me, my father went to the industry, the men said that they would look at the battery, and the masters were acquainted.
08.05.2020 19:20 # 6
peugeot murat
The malfunction of the vehicle is probably the same problem when the vehicle is overcharged by the dynamism of the car.
