urgent help or get this car from me :(
08.05.2020 19:59 # 1
mbsb44
friends I'm using the 2003 206 hdi. I press the starter of the vehicle, the starter takes quite late, or I work first, stop at the end of 3-5 seconds and then run hard again. I went to the industry, they measured the battery, they said, they said, look at the starter engine. In the evening, I got into the car and repeated the same thing. friends, I don't know who experienced the same problem, but I'm sure it didn't happen to me.
08.05.2020 19:59 # 2
dejawu1978
one of my friends had the same problem .. the room could not find a solution like you, finally sold the vehicle survived
08.05.2020 19:59 # 3
vpro
It is a battery if it works as a roof when it hits the car. It is good to try.
The cause of the stop of the Mars engine battery charger battery 3.
08.05.2020 19:59 # 4
ersin61
Man, I say look at the injectors
08.05.2020 19:59 # 5
conywolker
I think it may be a diesel pump. After waiting for a while, it does the job or it gives the same reaction to every starter. I need to know it.
08.05.2020 19:59 # 6
mbsb44
Let me say that it runs at the first start, the engine stops within 3-5 seconds. maybe not working after 5 or 6 attempts, but I can run it.
08.05.2020 19:59 # 7
Sercann
Good day, my teacher is not very sure, but probably there is a problem with the fuel system.
08.05.2020 19:59 # 8
conywolker
If you can shoot and put a video, a more accurate solution can be found
08.05.2020 19:59 # 9
mbsb44
the masters changed the battery, disassembled the charger, had the diesel filter overhauled, but we are still in the same place. By the way, we were 340 tl. Let's see what else will happen.
08.05.2020 19:59 # 10
GokhaN
looks like something related to the injector or diesel pump
08.05.2020 19:59 # 11
dejawu1978
Believe me, what my friend did not find this problem in you, by the way, he is a car mechanic in the profession.
Did you ever show it to the service ..?
08.05.2020 19:59 # 12
mbsb44
No, my teacher did not put it into service today, he called the master, he said there was a problem with the diesel pump's water sensor and diesel grip, but I am sure my hope is not left again. By the way, only the material said 150, let's see what happens.
08.05.2020 19:59 # 13
mbsb44
let's fix it, not the diesel pump, but the diesel filter ...
08.05.2020 19:59 # 14
dejawu1978
I hope your problem is solved, but if those parts are not changed, then tell the mechanic, if not, do not throw the old ones back.
08.05.2020 19:59 # 15
themurat54
So when I first start the car, I shiver. The same thing happened to me the gasket was burnt. If you want to see the seals of the gasket by inserting an apparatus into the water tank, themurat54 2016-10-06 12:04:53
08.05.2020 19:59 # 16
mbsb44
You are right, my teacher has a gasket on the diesel filter.
08.05.2020 19:59 # 17
Gokcesel
My teacher had the same problem in my car. The vehicle initially took a starter, stopped 3-5 seconds after idling, it did not work when I wanted to start and run back, it was trying hard.
I took the pump to the pump, I do not know what operation was done, he did not say. He said between 150 and 500, I gave 200 pounds, he is currently working in a single starter.
Take it to the pumper will solve your problem. If you were in Ankara, I would have directed you, unfortunately, you were in Malatya.
08.05.2020 19:59 # 18
mbsb44
GOD be pleased with you, do not ask my teacher. No, the battery changed to the ground, then the starter dynamo was removed and looked after, the diesel filter changed, then the diesel puller installation changed completely. Otherwise, there are no malatya or pumpers. The masters disassemble and send to Antebe and they want the money of the world. This is my teacher, bring me the last pump, said, let me dismantle the master, I couldn't trust it anymore, I tied the car so that it would not happen at this time.
08.05.2020 19:59 # 19
peugeot206sahibi
HAMM I HAVE THE SAME PROBLEM I HAVE TO FOLLOW THE TOPIC IF I HAVE A SOLUTION, I WILL MAKE ME MAKE IT WORK VERY LATE
08.05.2020 19:59 # 20
Gokcesel
[QUOTE = mbsb44] GOD bless you, don't ask my teacher. No, the battery changed to the ground, then the starter dynamo was removed and looked after, the diesel filter changed, then the diesel puller installation changed completely. Otherwise, there are no malatya or pumpers. The masters disassemble and send to Antebe and they want the money of the world. This is my teacher, bring me the last pump, I said, let me disconnect the pump. Master, I couldn't trust it anymore. I tied the car so it would not happen at this time.
[QUOTE = owner of peugeot206] HOCAM I HAVE THE SAME PROBLEM I HAVE FOLLOWING THE SUBJECT IF I HAVE A SOLUTION I HAVE MAKE ME MAKE IT LATE [/ QUOTE]
Look at the transparent pipe with green socket in the picture, is it foamy? The period when my vehicle did not work was foamy foamy white. He showed me that pipe while giving it to the pumper, and when I got the car it looked like it is now.
Gokcesel 2016-10-28 01:36:25
Page : / 2
